Tip & How-To about Cell Phones
Blackberry MEP Unlock Code
Hello
www.blackberryimeiunlockcodes.com
How to Enter Unlock Codes on BlackBerry
1) Need a SIM card inserted into the phone
2) Click on manage connections, select turn all connections off
3) Go to Settings Menu, Options, Advanced Options and then SIM Card.
4) Hit the menu button and select show keyboard
5) Type in MEPD using the keyboard (nothing will show on screen)
0) You will see the Personalization screen, that show SIM> Disabled, Network> Active, Network Subset> Disabled
6) Type in MEP2 (Nothing will show on screen - use "Alt" to show numbers.) another screen pops up for the code.
7) Now it will say enter network mep code Enter the code that we send you, remember you ONLY have 10 chances to get it right
8) Press the enter key
9) A message will appear saying code accepted
00) On Personalization screen you will see the Network> Inactive.
10) Turn device off, insert SIM of your choice if have not done so already
11) Turn the phone back on
12) Go to Options, then Mobile Network, on the third row switch it to GSM/UMTS and you're done.
Issues:
1) If you have issues with the phone not recognizing the network, make sure the radio is on by making sure it is not low on power.
2) Sometimes the phone requires you to do "m e p p d" instead of "m e p d" and if that occurs, you will need to do "m e p p 2" instead of "m e p 2"
3) If you have issues with the network not working after you have finished and the phone isn't low on power, switch from Global to GSM to Verizon a few times (keep on doing) and after 3 times of the process completed, leave it on GSM. Should work now.
Removing "Activation Required" on the screen:
1) On the main screen of the phone, press ##000000
2) For the Mobile Directory Number, put in your phone number in there.
3) After you have done that, press the menu button to save the options and the phone will automatically restart
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Cell Phones Logo
unlock my bb
the best way is through unlock codes, try codes from http://www.unlocking4u.com/
Aug 06, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
where do i input unlock code in blackberry pearl 8110
It's a clear and fully detailed guide on how to unlock BlackBerry pearl :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Jul 06, 2010 | RIM BlackBerry Pearl 8100
146 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
