Tip & How-To about Cell Phones
How To Unlock BlackBerry Bold
Hello
www.blackberryimeiunlockcodes.com
How to Enter Unlock Codes on BlackBerry Bold
1) Need a SIM card inserted into the phone
2) Click on manage connections, select turn all connections off
3) Go to Settings Menu, Options, Advanced Options and then SIM Card.
4) Hit the menu button and select show keyboard
5) Type in MEPD using the keyboard (nothing will show on screen)
0) You will see the Personalization screen, that show SIM> Disabled, Network> Active, Network Subset> Disabled
6) Type in MEP2 (Nothing will show on screen - use "Alt" to show numbers.) another screen pops up for the code.
7) Now it will say enter network mep code Enter the code that we send you, remember you ONLY have 10 chances to get it right
8) Press the enter key
9) A message will appear saying code accepted
00) On Personalization screen you will see the Network> Inactive.
10) Turn device off, insert SIM of your choice if have not done so already
11) Turn the phone back on
12) Go to Options, then Mobile Network, on the third row switch it to GSM/UMTS and you're done.
Issues:
1) If you have issues with the phone not recognizing the network, make sure the radio is on by making sure it is not low on power.
2) Sometimes the phone requires you to do "m e p p d" instead of "m e p d" and if that occurs, you will need to do "m e p p 2" instead of "m e p 2"
3) If you have issues with the network not working after you have finished and the phone isn't low on power, switch from Global to GSM to Verizon a few times (keep on doing) and after 3 times of the process completed, leave it on GSM. Should work now.
Removing "Activation Required" on the screen:
1) On the main screen of the phone, press ##000000
2) For the Mobile Directory Number, put in your phone number in there.
3) After you have done that, press the menu button to save the options and the phone will automatically restart
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Cell Phones Logo
unlock rogers blackberry bold 9000
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry BOLD 9000 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry BOLD 9000 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Nov 10, 2010 | Cell Phones
hi..i'm kaye..i would like to unlock my blackberry bold 9700 that was locked to Globe network Philippines. could you please give me my unlock code? or send it via email - kayedm1231@yahoo.com my IMEI # is: 359564.03.476291.6 thanks a lot
You can unlock any blackberry from any network & after unlocking you can use with any GSM provider around the world by just entering one time unlock code which is comes from server based on IMEI & unique code for every set.
Unlock 3-Hutchison Blackberry
Unlock Airtel Blackberry
Unlock AT&T Blackberry
Unlock Bell Blackberry
Unlock Cingular Blackberry
Unlock Claro Blackberry
Unlock Comcel Blackberry
Unlock Cable & Wireless Blackberry
Unlock Digicel Blackberry
Unlock Etisalat Blackberry
Unlock Fido Blackberry
Unlock Globalstar Blackberry
Unlock Movistar Blackberry
Unlock O2 Blackberry
Unlock Orange Blackberry
Unlock Rogers Blackberry
Unlock Sprint Blackberry
Unlock T-Mobile Blackberry
Unlock Telcel Blackberry
Unlock Tele2 Blackberry
Unlock Telus Blackberry
Unlock Verizon Blackberry
Unlock Virgin Blackberry
Unlock Vodafone Blackberry
Unlock 9900 Blackberry
Unlock 9700 Bold Blackberry
Unlock 9650 Blackberry
Unlock 9630 Tour Blackberry
Unlock 9600 Blackberry
Unlock 9550 Storm2 Blackberry
Unlock 9530 Storm Blackberry
Unlock 9520 Blackberry
Unlock 9500 Blackberry
Unlock 9300 Blackberry
Unlock 9100 Blackberry
Unlock 9000 Bold Blackberry
Unlock 8900 Curve Blackberry
Unlock 8830 Blackberry
Unlock 8820 Blackberry
Unlock 8810 Blackberry
Unlock 8800 Blackberry
Unlock 8700 Blackberry
Unlock 8520 Blackberry
Unlock 8500 Blackberry
Unlock 8350 Blackberry
Unlock 8330 Curve Blackberry
Unlock 8320 Curve Blackberry
Unlock 8310 Blackberry
Unlock 8300 Blackberry
Unlock 8230 Blackberry
Unlock 8220 Blackberry
Unlock 8120 Pearl Blackberry
Unlock 8110 Blackberry
Unlock 8100 Blackberry
Unlock Gemini Blackberry
Unlock Javelin Blackberry
Unlock Niagara Blackberry
Unlock Thunder Blackberry
Unlock Torch 9800 Blackberry
Aug 17, 2010 | Cell Phones
Need 2 unlock at&t blackberry bold 9700, so I can use with tmobile sim card... FREE OF CHARGE...
Yes you can unlock your phone & can use with any GSM provider also code is different for every set generate from server based on IMEI. After unlocking you can use with any GSM provider.
This sites will help you a lot.
http://www.blackberryimeiunlockcodes.com/unlock-vodafone-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-virgin-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-verizon-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-t-mobile-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-telus-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-telcel-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-sprint-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-rogers-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-orange-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-o2-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-movistar-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-fido-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-etisalat-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-digicel-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-comcel-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-cingular-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-blackberry-phone.html
http://www.blackberryimeiunlockcodes.com/unlock-blackberry-network.html
http://www.blackberryimeiunlockcodes.com/unlock-bell-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-att-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-airtel-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-9700-bold-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-9630-tour-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-9550-storm2-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-9530-storm-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-9000-bold-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8900-curve-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8830-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8820-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8520-blackberry-imei-code.htm
http://www.blackberryimeiunlockcodes.com/unlock-8330-curve-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8320-curve-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/unlock-8120-pearl-blackberry-imei-code.html
http://www.blackberryimeiunlockcodes.com/rim-blackberry-unlocking-instructions.html
http://www.blackberryimeiunlockcodes.com/blackberry-imei-unlock-code-reseller.html
http://www.blackberryimeiunlockcodes.com/blackberry-imei-unlock-code-faq.html
Aug 06, 2010 | RIM BlackBerry Bold 9700 Smartphone
unlock my bb
the best way is through unlock codes, try codes from http://www.unlocking4u.com/
Aug 06, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
unlocking my mobile phone please
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry bold 9000 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Dec 11, 2008 | Cell Phones
153 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
