Tip & How-To about Car Audio & Video
My amp keeps TURNING off and on.
If it just started, you have an equipment or wiring problem. Check the wires first, that's easy. Otherwise, the amp may be bad, check the warranty if its new. Maybe you can get a replacement.
If it's always happened, some cars have an factory amp for the rear factory speakers hidden in the wiring. Sometimes between body panels. If you didn't bypass that, you're more than likely blowing out the new amp with too much power causing it to shut itself down. (protected mode or keep blowing fuses) Could be a blown speaker, bad ground, internal damage, RCA cable problem, the list goes on and on. Find out the preoutput voltage of your headunit and set the gain to what that is and nothing else LEAVE IT THERE, the gain isnt a volume knob for your amp its to get the amp and the radio on the same page (i.e. radios at 50% volume and so is the amp) if you turn it down too low that will make the amp very sensitive to volume adjustments and your amp will be at 100% while the raidos at like 50 or 75% and once you go past the 50 or 75 on the radio the amps going to keep trying to play higher even though its already maxing out which is going to cause it to clip and cause distortion untill it goes into protect mode. Hope this was helpfull to some one
Car Audio & Video Logo
heater will not come on. flashes code 125 &
These codes indicate that you have a bad temperature sensor. Once replaced, the error codes will go away.
This is an easy do it your self project, or it may still be under warranty. Check with your install date; if you have installed the heater 1 year or less (single piece of Pentair Equipment) or if you recently built the pool and installed 3 seperate pieces of Pentair Equipment, your warranty is extended to coverage for three years.
Dec 06, 2010 | Pentair 460734 MasterTemp Heater Natural...
my gsxr600 keeps blowing 30 amp fuses
I'm assuming bike is still under warranty, so theyshould fix it free. Otherwise you will have to trace each wire individually. Do this with ignition off an then check all positive wires to ground. If you have continuity then you have found the bad wire. Good Luck.
Oct 07, 2009 | 2008 Suzuki GSX-R 600
engine wont start
The mechanic should check on the connection of the wires to the battery and the ignition system . Because of may be there is a wire that have been accidentally been disconnected. When you remove the the speaker box , and the amps out of the car.Check the wires , the fuses and the ignition switch and the ignition switch wires and fuses. It is because when you place the amps and the speaker box ,May be there is a wire that you accidentally disconnected that's why it wont start.When you place back all the equipment to the car.
Sep 04, 2009 | 2001 Toyota MR2 Spyder
no sound from speakers
Did you just install the radio? if you did make sure you get all the right color coded to the right speaker. I don't know of any car radio would have relay install, fuse would be more like it and more safe when it come to sensitve electronics. did this problems just arised or you had for awhile and now it just quit. If the systems has been in the car for while and it just started to happens than you may have bad connect to your speakers, check both post + & - making sure they have good contact; check to make sure speakers is good and not blown. check & trace the speaker wires making sure is not cut from pinching. if the wires check out than you have an audio problem from the unit it self. most of the radio equip with 2 fuses, one internal and external. if the radio has no warranty left on it than you can open the cover up and check making sure fuse looks good. if its still under warranty, do not mess with it, take the unit back or contact manufacture company how to ship and where to ship to. I hope that help some..good luck!!
Jul 12, 2009 | Car Audio & Video
Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Jan 17, 2006 | Yamaha DVX-S120 System
1,781 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
