Tip & How-To about Car Audio & Video
My lights dim in my car, is this bad and what can I do to stop this from happening?
Lights dimming in your car is an indicator of a low voltage problem. This can be caused many problems. You might want to have your system checked out to make sure it is running smoothly. Low voltage can be a serious problem. Low voltage will cause an amplifier to put out a DC voltage rather that AC, which can damage your speakers. Low voltage can also cause damage to an amplifier by not providing enough power to the amp to run properly. You can add batteries and/or capacitors to the system to help with voltage problems. Please consult with a professional to make sure you get what you need for your specific setup.
Car Audio & Video Logo
solenoid clicks starter won't turn
MY RELAY SOUND LIKE A JACKHAMER
Jan 01, 2012 | 1990 Ford F150
my 03 yukon xl is having a issue with entire electrical system check engine light dianostic shows low battery low charge when it reads,when operating front power windows all lights dims.scanner shows good batery voltage.
Check all grounds ie motor to body ground strap connections for corossion, battery to motor ground, battery to body ground. You have to check under bolt to see if there is coeossion. Bad grounding can cause all sorts of electrical problems
Jul 29, 2010 | 2003 GMC Yukon XL
battery and brake lights flicker and headlights dim
Sounds like a low voltage problem, alternator not charging properly. When you press the gass the motor takes more juice from your battery to fire the spark plugs have you had your charging system tested (most auto parts places do it for free)? Either that or a loose wire causing the short. Check all grounds under the hood and make sure they all have a good contact
Aug 06, 2009 | 2001 Mitsubishi Eclipse
highbeam lights very dim
Check the ground wire from them. It is what causes them to be dim like this. It likely has a bad connection.
May 27, 2009 | 1994 Suzuki Sidekick
dim dash lights
Did you have the alternator check? Low voltage will cause light dimming.
May 27, 2009 | 1992 Volkswagen Cabriolet
1,398 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
