Tip & How-To about Apple iPhone Smartphone
IPhone Scree Wont Sense Touch
This is a broken digitizer problem.. go to youtube and search for iphone 3g/3gs digitizer replacement, and they will tell you how to do it. then go to ebay and search for iphone 3g/3gs digitizer and buy one. they cost around $20. then replace it as shown in the video. you can also search craigslist. there are people everywhere that will do this for you for about $50.
Apple iPhone Smartphone Logo
Just how can you the distinction between an iphone 3g and an iphone 3gs?
Yes there's a distinction between the iPhone 3G screen/digitizer and the iPhone 3Gs screen/digitizer. The glass is exactly the same however the cable for the digitizer relationship is not. You can inform the once the iPhone is opened by you that the link is various. The unlock iphone 3gs connection has a broader bill in the center and can not match. If someone is wanted by you to emerge to your house or company and replace
May 04, 2013 | Cell Phones
What is the differeance between iphone g3 to phone gs3?
the main difference between the iphone 3g and iphone 3gs is the speed. but here are the specifications for both phones
weight: the 3gs is slightly heavier at 135g memory: iphone 3g only has two options an 8gb or a 16gb whereas for the iphone 3gs it has 8gb/16gb/32gb camera: the iphone 3g has 2mp camera that can only take pictures while the ihpne 3gs has a 3.15mp camera that can also capture videos cpu/processor: iphone 3g has ARM 11 412 MHz, PowerVR MBX-Lite graphics while the iphone 3gs has 600 MHz ARM Cortex A8 processor, PowerVR SGX535 GPU. So the 3gs is faster and it means less or no lag on apps
the 3gs has a digital compass
and the 3gs has a longer battery time than the 3g.
to summaarize, the iphone 3gs is faster, has longer battery life, and has a bigger memory (as it comes with a 32gb version).
Apr 24, 2011 | Samsung Omnia Pro B7320 Smartphone
I have an 8gb Iphone that has a problem on the screen , it's like when you press on an ara of the screen does not work, some friends that has a dead line, it's not like you see a line on it, it's like the sensors on that particular area are damage. I need to find out where to find a new screen and how to replace it.
Okay try this, ive been doing this and making a TON of money on it recently... go you youtube and search for iPhone 3g (or whatever kind you have, 3g,3gs,2g) digitizer replacement.
you can go to ebay and search for iphone 3g digitizer and it will come up with tons of links to buy them, order one, its about $20 and then put it on like said in the youtube vidoes... i dont suggest using Direct Fix's or PDAParts.com's video...
Basic instructions,
take out two screws on bottom of phone,
take a suction cup the the glass of the phone and pull up,
once inside look for where the cables connect and disconnect,
unscrew 6 screws and CAREFULLY pull off the LCD,
go ahead an rip off all the glass from the plastic frame,
replace with new digitizer (glass),
and put LCD back on,
re-assemble and put screws back in the bottom (dont forget to plug cables in),
power up iPhone,
you good! (:
this will only work with iPhone 3g/3gs
original iphones your kind of just stuck with a paper-weight
May 11, 2010 | Apple iPhone Smartphone
the bottom slider wont slide to unlock on iphone i tried by resetting it but to no avail?
you have a broken digitizer my freind, go to youtube and serach for 3g/3gs digitizer replacement, they will tell you how to do it and where to buy one. good luck
May 05, 2010 | Apple iPhone Smartphone
3g iphone keys q and #1 unresponsive
dead digitizer, search youtube for the solution and buy a part from ebay, if you dont wanna open up your phone then search craigslist. people will do it for you for about $50 (only works for iphone 3g/3gs)
Apr 01, 2010 | Apple iPhone Smartphone
845 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
