Tip & How-To about Computers & Internet
How to setup as many VPS on your pc as you can!
Nowadays many people are paying for VPS(virtual personal server) witch in terms is just like having a personal computer that you control remotely! What I have realized while using such services is that on a sole PC can be up to 10 virtual machines with up to 10 OS installed(or better said emulated)! Practicly they have a small application called WINDOWS VIRTUAL PC wich is using .VHD files. The .VHD files are virtual hard disks made after an OS! And to just boot it you create an image wich you run. After that you can set a number of RAM or hdd resourses! And that practicly means cheating because you are no longer the only user on that PC. If it comes to hosting a game server then I reccomend buying a mediocre PC to be left open 24h a day everyday. That way you are sure nobody else is in that PC.And for web hosting just go with the popular webhosting suppliers because a VPS is nothing more than a way to extract a large amount of money out af nothing!
Computers & Internet Logo
What is & where is virtual private server hosting?
its commenly known as VPS anjd is used for something like TS3 Muble and other voice services and you can find one here https://www.hosteurope.de/en/Server/Virtual-Server/ else you can search on google.com
Nov 19, 2014 | Computers & Internet
I can no longer access mail2web.com on my laptop. I get a message that says "windows could not automatically detect this network's proxy settings".
may be a proxy server problem if your using windows then By using your Windows VPS as a proxy server you will get the best performance and have the most control over the proxy. Setting up your Windows VPS to work as a proxy server is simple, all you need to do is install proxy server software, such as CCProxy, and add a rule to your firewall.
Feb 16, 2014 | Toshiba Satellite Computers & Internet
The best offer reseller and VPS reseller hosting plans? What will be better to choose? What are the advantages of using this or that hosting solution?
I am using the following companies reseller account and they are providing excellent services at very cheap rate. Usually such rate is provided for shared hosting services by hosting companies.
You will get a reseller hosting package at only $6/mo. And later you can also upgrade it if you want it easily.
Reseller Web Hosting
Apr 24, 2011 | Computers & Internet
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
457 people viewed this tip
David Payne
David Payne
