Tip & How-To about Computers & Internet
How To keep your PC or laptop healthy
These are some of the easy ways:
1> Clean the temporary files everytime you open or shut down your PC.
Path: Start->Run->%temp%-> enter->select all files and delete them
2> Defragment your hard disk once in a while every 3 to six months.
3> Reset your browser.
4> Firewall your internet connection and keep the spam blockers and junk filters in tact.
Thats It. Do these all and computer will be alive and kicking and would always love you.
Prasanth.
Please Rate
Computers & Internet Logo
how to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
my desktop is running very slow
to speed up your desktop you should perform following operations :-
  • go to your start button, and click on the option accessory. Then go to system tools in the accessory option and then click on disk clean up option.
  • the second method to speed up your desktop is- press windows button+r to open the run window.
  • then type %temp% in the run window dialog box and then press enter.
  • whole temporary files of your desktop will appear in a window. then press ctrl+A to select all files and the press Shift+delete to delete those files permanently.
  • deletion of these temporary files does not harm your desktop.
  • Another way to speed up your desktop is to clear prefetch files from your desktop.
  • press window key+r and then type prefetch keyword in the dialog box and press enter.
  • then a window will appear.select all the files shown in the window and delete them by pressing shift+delete
Jun 01, 2011 | Microsoft Windows XP Professional for PC
Freezes or won't open programs after running a few hours
Delete the temporary files form the computer. To do so Click Start-> Run-> type %temp%-> hit enter. Select everything and delete it.
Same way delete the temporary files from windows well. Click My computer-> Local Disk-> Windows-> temp
Also delete prefatch under windows. ClickMy computer-> Local Disk-> Windows-> prefatch.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Computers & Internet
My machine seems to slow down alot what can I do to fix this?
Try to restart your computer everyday and not just log it off.
Try and see if this works.
Jul 02, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
aspire 5100 wont save when i shut down
It appears that the C dirve is using 98% of space. Let us try to delete some temporary files, to do so, click Start Menu> Run> type %temp% and hit enter. It will open the temporary folder, delete all the files listed in this folder. Now, again click Start> Run> type prefetch and hit enter, it will open the prefetch folder, delete all the files listed on it. It should take care of the issue.
May 20, 2010 | Acer Aspire 5100 Notebook
115 people viewed this tip
David Payne
David Payne
