Tip & How-To about Toshiba 32HL67 32 in. LCD Television
With the power OFF, remove the power supply board (on right) and check all solder joints with a magenfiying glass. Touch up any that don't look right.
You will notice two of the mounting holes on the left have grounding tabs.
When I measured mine, there was over 8M ohms of resistance between the two (but both tabs get tied to ground when the screws are in place).
I soldered a wire on the solder side between both grounding tabs, then tied it to the green grounding wire that comes off the middle board.
Now "chassis ground" is all tied to the same potiental. The TV has been cycled (turned on and off) 6 times successfully. Like all of you with this set, I hope it stays working.
jpbjr
