Tip & How-To about Computers & Internet
Low Disk Space in Windows XP
Click on Start | Run, type Regedit, and click on OK. Browse to HKEY_CURRENT _USER\
Software\Microsoft\Windows\ CurrentVersion\Policies\Explorer. If there's no DWORD value
there, create a new one called NoLowDiskSpaceChecks.
Once you are in the Explorer folder, select Edit from the menu, select New, and choose DWORD
value. Now double-click on the new DWORD and assign it the value 1. Log off and log on once
more, and you won't receive the warning again. Note that the warning will be turned off for
all your hard drives.
1. Start the registry editor (regedit.exe).
2. Navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer.
3. Go to the Edit menu, and select New - DWORD value.
4. Enter a name of NoLowDiskSpaceChecks, and press Enter.
5. Double-click the new value, set it to 1, and click OK.
6. Close the registry editor.
7. Log off and log on for the change to take effect.
REM copy here regini
"NoLowDiskSpaceChecks" = REG_DWORD 1 REM end copy here
If you want to keep the partition intact, and just want to get rid of the low
space warnings:
Control Panel (Classic view) > Administrative Toots > Computer Management >
highlight Disk Management in the left pane > right
click in the right pane on the D partition and select Change Drive Letter and
Paths > Click the Remove button > click OK
If you want to access the volume later, you can reassign a drive letter. The
data on the disk will not be damaged.
Computers & Internet Logo
how to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
how to enable folder options disabled by malicious command prompt code in Windows Xp ?
Here's How:
  1. Click Start
  2. Click Run
  3. Type REGEDIT
  4. Click OK
    The Registry Editor will now open
  5. Browse to the following key:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKCU stands for HKEY_CURRENT_USER
  6. In the right pane, look for the value: NoFolderOptions
  7. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  8. Now browse to the following key:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKLM stands for HKEY_LOCAL_MACHINE
  9. In the right pane, look for the value: NoFolderOptions
  10. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  11. Close the Registry by choosing File | Exit
  12. You should now be able to access the Folder Options menu. If not, reboot into Safe Mode and repeat the steps outlined above.
Jan 27, 2009 | Computers & Internet
hide task manager
hi dear
start menu, run
type regedit
find this....
change dword to 000000000
oke
Mar 19, 2008 | Microsoft Windows XP Professional
129 people viewed this tip
David Payne
David Payne
