Tip & How-To about Computers & Internet
Speeding Up Start Menu Button in Windows XP
Speeding up the Start Menu (Windows XP)
Most of us are experiencing delay (slow) opening the StartMenu when we click over it to open the All programs, and others features whichare attached to it. We can speed up this by tweaking the registry withoutaffecting to the operating system. This default speed can be adjusted with aquick Registry modification.
To do this, go click run – type regedit, the registry editor window will open, go to HKEY_CURRENT_USER
HKEY_CURRENT_USERControl panel
HKEY_CURRENT_USERControl panelDesktop
HKEY_CURRENT_USERControl panelDesktopMenuShowDelay.
Double click MenuShowDelay to open, you’ll notice that thevalue is 400, now set it to 0 (zero), click OK and close the registry editor,now check the speed of the whether it has taken effect or not. The Start MenuSpeed should have been changed to full speed by now.
For better reference, I've included the graphical representation to perform this tweak step by step:
Try this yourself and enjoy the speed of the Start Menu in windows XPwithout spending a penny or installing additional applications. Good Luck.
Computers & Internet Logo
my computer is too slow - how do I make it faster?
Slow Start Up
There can be a variety of reasons to Windows loading slow during start up. Go to Run, type msconfig and hit enter. Under the 'Start Up' tab, uncheck the unwanted programs and press OK. Things should be a bit fine the next time Windows boots.
Another program worth mentioning here is StartUp Delayer which will help in setting after how much time programs should be loaded after Windows boots. For instance, you could set your instant messenger program to load 50 seconds after Windows starts up.
Slow Loading Start Menu
If the Start Menu items are loading slowly, you can open the Registry Editor by typing in the Run menu 'regedit.exe' and pressing Enter. Go to HKEY_CURRENT_USERControl PanelDesktop. Look for MenuShowDelay, and double click to edit the value. The lower the number specified, the faster the Start Menu will load.
Slow Right Click Context Menu
Probably the Windows Right Click menu on your computer is loading slow because too many programs added unwanted entries there. Just download this program called Mmm, install it and then modify your context menu to remove unwanted items to speed it up.
win-fixes-send-to.jpg Slow Send To Menu
If the Send To menu loads slowly, you can type 'sendto' in the Run Dialog, and remove unwanted items in the Explorer Window that appears. This should add some speed to it.
Slow Defragmentation
The Windows Defragmenter can't get any slower. You need to have an alternative to the Windows Defragmenter, and Defraggler is just one of the best ones available in the market. It's free, and works like a charm and can speed up defragmentation manifold. For some alternatives, see Five Free Programs to Defragment your PC.
Aug 11, 2011 | Computers & Internet
HOW DO I OPEN MY WEB BROWSER?
Hi!
Opening your web browser in Windows is very simple: it's located in the startmenu. Click op start-button in the bottom-left-corner of your screen, click on All Programs. There you search for the entry called Internet Explorer. Clicking it will open your browser!
Aug 10, 2011 | Microsoft Internet Explorer 7
I WAS CLEANING UP MY SYSTEM AND DELEATING SOME UNUSED PROGRAMS AND NOW I DONT HAVE A START UP MENU HELP! I HAVE WINDOWS XP ON MY SYSTEM
ok Im going to give you a registry entry
that should restore your startmenu
REGFIX
What you do is save it then right click and select
MERGE .
Apr 01, 2009 | Computers & Internet
I've lost my ''Recently used program list'' from the Start menu in Windows XP (Home Edition). How do I get this list option back?
hey jeff
Go to Control Panel >TaskBar and StartMenu properties > StartMenu > Customize > Advanced > Re-check the box for "list my most recently opened documents".
hope this is what your looking for.
Jan 24, 2009 | Microsoft Windows XP Home Edition
143 people viewed this tip
David Payne
David Payne
