Tip & How-To about Google Chrome
Safer Browsing sign up for a Google API key
Keep in mind that this API is experimental and we fully expect to change the protocol over time to improve the service. You must have a Google Account to get an Safe Browsing API key, and your API key will be connected to your Google Account.
The Safe Browsing API is an API that enables client applications to check URLs against Google's constantly updated blacklists of suspected phishing and malware pages.
http://code.google.com/apis/safebrowsing/key_signup.html
Google Chrome Logo
Oil type for 2003 Toyota 4runner v6?
-Read its owner manual specification page. Most Toyota use ApI Service SJ
It doesn't matter what grade or brand.
But keep in mind. Winter prefer 5-30 and summer 10-30.
Good luck
Mai
Mar 17, 2014 | Cars & Trucks
I need an oil change and I cant find an oil that has SG in the label. What should I use?
You can use oil with an API rating of at least SG and therefore can use today's oils with an SN rating. The API service rating is basically a classification assigned to signify the oil's ability to reduce friction and oil consumption, improve emissions, and provide better lubrication. The API ratings are backwards compatible, but not vice versa, meaning SN will work for SG but SJ will not work for SM.
Feb 06, 2011 | 1991 Buick Park Avenue
insuffient system resources exist to complete the api
Your problem can be cured by simply increasing your paging file size or adding more Ram. Here is an explanation of what an API is and does.
An application programming interface (API) is an interface implemented by a software program to enable interaction with other software, similar to the way a user interface facilitates interaction between humans and computers. APIs are implemented by applications, libraries andoperating systems to determine the vocabulary and calling conventions the programmer should employ to use their services. It may include specifications for routines, data structures, object classes and protocols used to communicate between the consumer and implementer of the AP
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Oil type
Read your owner's manual. If not.
Proper engine oil selection is very important for optimum engine performance, efficiency and durability. A new service API classification category has been adopted. The designation for this category is "SH". The "SH" category is intended to replace the "SG"category and provide improved performance in: deposit control, oil oxidation, wear, rust, and corrosion protection. "SH" category oils may be used in applications where "SG" and earlier categories are recommended. The appropriate SAE viscosity grade depends on existing climatic conditions. Refer to the temperature chart below when selecting viscosity grades for expected temperature ranges. Brief variations in temperature are no cause for alarm. Lubricants that do not list both an SAE grade number and an API service classification on the container should not be used. 7897780.jpg
Jun 20, 2009 | 2001 Hyundai Tiburon
327 people viewed this tip
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Ricosta Beta
Ricosta Beta
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
