Tip & How-To about Plumbing
Pool loosing water?
Maybe you cannot decide if the loss of water in your pool is a leak or evaporation. If you place a bucket of the pool water on a step in the pool with the water level the same inside and ouside the bucket exactly the same and run the pool pump for a day, then you will be able to tell if youi have a leak. A leak would result in a lower level in the pool after running the pump for the day. If the levels stay the same, then it is evaoporation.
Plumbing Logo
How to check for leaks in inground pool?
start by making sure you actually have a leak. perform a 'bucket' test. if that proves there is a leak, the next step is to pressure test the underground lines. this is usually past the skill level of most pool owners. if the lines test ok, the next test is to either swim and check the openings with dye or get someone in to perform a leak test.
Sep 09, 2014 | Pool & Spa
my radiator is lossing water and no sign of leakage
great question, a nice symptoms posted.!!!! and car !
The water, (coolant) can only go 3 places.
1: on the ground, (or at passenger toes, look there)
2: into the inside of the engine (see engine oil turn to milk chocolate shake?
3: in the the A/T tranny pan, same thing same milk.
4: out the exhaust, pipe end point, see steam there ALL THE TIME?
this is short term loss.
long term is normal this is evaporation.
here are the tests.
1: no steam ,tail
2: no carbon or oil in rad neck (cold)
3: milk in pans. per above.
4: rad neck tester (green/blue) chem test unit finds exh. gasses in the rad.
5: same place, RAD leak down tester.
6: compression test. all cyl.
7: cylinder leak down tester can even show me here it leaks (ASK, this is advanced testing methods but easy to do)
Jun 25, 2014 | 1998 Toyota Camry
my pool has a leak i cant find
If you have an auto fill turn it off. Do not add water and watch the level of the pool. The water loss will drop when it stops past the leak. Most leaks are in the skimmer throat.
Aug 24, 2013 | Pool & Spa
DE back flow into pool
The system is back-siphoning when the pump is turned off. This means the check valve is not totally closing -- it has a slight leak-by issue.
Is the check valve installed in the proper orientation? If not, it's not working as it should.
Mar 09, 2009 | Water Pik Flow Valve Assy. Series II...
1,297 people viewed this tip
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
