Tip & How-To about D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch
Trying to connect 3 pc to a dlink switch
I have an internet connection at home which 512 Mbps. I have bought Dlink Switch DES-1005d. I have 3 pc at home. I want to share the internet connection among the three pc. I have tried just by connecting the pc with CAT5 cables. I just have the received packet and then I do not have internet connection at all. Please can someone help me?
Thanks in advance for your help.
Best Regards
Jerman
D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
how to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
My home network is such that I have a DLink Gigabit switch right behind my DSL router to dispatch network connections through the home. I already connected several devices that work without problem. One other connection goes to the study, where I want to add 4 more connections by using my Dlink DES-1005D. When I connect my PC (Vista, with 2 Gbit connections) to the switch it blinks a couple of times greenand then turns orange, resulting in limited connectivity and unable to access the internet. When I leave out the switch and connect my PC to the wall, all works fine, but than I cant connect my printer, my laptop,... Any ideas? Thanks in advance!
Check the network settings of your pc in network and sharing, adapter settings , right click local area connection and press properties, click IPv4 and look at its properties. Ensure ip and DNS are bother set to auto.
press start, type cmd right click the grey chalk board press run as administrator. Type ipconfig /release then type ipconfig /renew
also try a different port/cable if it is a gigabit switch an orange light means it is running below the speed. I.e. 10/100 if it is working correctly the lights should be green.
Apr 06, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
1,360 people viewed this tip
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
