Tip & How-To about Computers & Internet
Tips of running your favourite contents through run command in window based operating system.
Now a days people wants everything to be done easily. Just like today I am
helping you in making the everything run easily through the run command
available in the window operating system.
Just make a shortcut of a program and put that shortcut to your system widow
directory, or type the %windir% in run and the system window directory will be
appear. Now just type that shortcut name in run and thats all.
For eg.:->
If I want one JayduttDave.ppt file being open through run then I would make a
shortcut of that file and put it into a system window directory. Then after I will
just have to do is to type the JayduttDave.ppt(case insensitive) in run and my ppt
file will be opened.
I can also make a short command by renaming the shortcut to a small one.
For eg.:->
Instead of pasting the shortcut directly into system window directory I would
rename it into JD.ppt and now I can also run the above same ppt only by typing
the JD.ppt into the run.
Try it and comment it as per your likes.
Computers & Internet Logo
my microsoft power point need a product key
You can extend your office if u don't have product key
1. Go to Start > All Program > Accessories and right click on "Command Prompt" then click on"Run as administrator". Alternatively you can run Command Prompt as administrator by typing"cmd" in the start menu search box and pressing Shift + Ctrl + Enter.
Then, Go to
C:\Program Files\Common Files\microsoft shared\OfficeSoftwareProtectionPlatform\OSPPREARM.EXE (copy path)
And (paste) in command prompt
So type the above full path of the tool OSPPREARM.exe in the command prompt and hit enter. Your command should look like
"C:\Program Files\Common Files\microsoft shared\OfficeSoftwareProtectionPlatform\OSPPREARM.exe"
You are done! But remind that you can apply this trick only for five times. If you run the above command for the sixth time you will get an error message like this
Warning
It is recommended to wait until you only have only 1 day to activate left before doing this to make the most out of the 6 times you have to use this rearm option. If you use this command after done 30 days/expire day your office will not be genuine so use this before expiry day/30days...
Jun 29, 2011 | Microsoft Office PowerPoint Home and...
i don't remember ip of my router
Good day.
Here are the easy steps:
1.Press Windows + R key on your keyboard.
2.This should bring up the Run dialog box.
3.Type in CMD to bring up the command prompt. -Type in ipconfig on the command prompt and press enter -The default gateway ip address should be the ip address of your router.
I hope this helps you today. :-)
Jun 26, 2011 | D-Link DIR-600 Router
I have the BSOD problem - msconfig admin privileges
msconfig is just a nice GUI to the keys in registry, what you may have is a driver or disk problem.
run chkdsk C: /F (or /P if in repair console)
instead of running msconfig, run services.msc and disable everything that doesn't belong to microsoft.
with another computer, download Autoruns.zip
copy it to the troubled machine and run it via the command line.
It's a very nice utility, msconfig on steroids :)
Sep 15, 2009 | Dell XPS M1530 Laptop
Not able to download software
well the run command is just a confirm button. it has to do with java. go ahead and click it and everything will keep going as normally. proud to be part of your help
-brandon
Mar 07, 2009 | Sakar Digital Concepts Digital Camera and...
Each day my computer seems to run slower and slower.
Run the commands in your Accessories and also don't forget you need to Defrag and run an Anti-Virus software. The proper programs are under Start>All Programs>System Tools>Disk Cleanup and Defrag. When the housekeeping is done, if your computer is still running slow then the best thing you can do is upgrade the amount of RAM. That will make a noticeable difference.
Please rate this solution.
Jan 09, 2009 | Compaq Presario V5005us Notebook
147 people viewed this tip
David Payne
David Payne
