Tip & How-To about Cell Phones
How to repair cellphone if it fell into water ?
1.Take the cell phone out of the water switched off the cell phone, take out the battery and SIM card from the cell phone.
2.Use the vacuum cleaner for around 25 minutes to dry the cell phone.Do not use microwave or a hair dryer to dry the cell phone. While microwave can literally burn the components & hair dryer can force moisture into the components.Don’t take the vacuum cleaner too close to the cell phone as this can again cause damage to the micro components.
3.Remove the moisture from the Cell phone by open it and keep it on a dry tissue paper or napkin for 6 – 8 hours or use BHEESTIE Bag.Reinsert the battery & SIM.
4. restart the cell phone. If the cell phone still shows up issues or doesn’t start go to service centre.
Please Vote for this Tip if you found it helpful….
Cell Phones Logo
I have nokia X6 mobile.My phone dropped in water today.I wipped of the water with towel well.Unfortunately unkowingly i tried to charge the and switch on the phone.at first it showed the display and then got switched off again.then it did not function.I worry if my phone had be short circuited and cannot be repaired.please advise.waiting for your response
It is highly probable you cell phone is beyond repair.
When you wet your cell, immediately remove the battery and SIM card, dry the phone as much as possible and place it in a warm place for several hours until it is completely dry. Replace the SIM card and battery, cross your fingers and hope your cell phone works as normal. If not then you need a new cell phone.
Aug 12, 2011 | Cell Phones
insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
water damage how can i try an fix it? on a samsung gravity 2
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Jul 18, 2010 | Samsung Gravity SGH-T459 Cell Phone
same problem. dropped in water. cannot find service.
HI,
The first thing you need to do is remove the battery and also the sim card from your phone.Next dry your phone.You can make the use of a towel to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel.Next make the use of a vacuum cleaner for up to 20 minutes in each accessible area of the phone.Be careful not to hold the vacuum too close to the phone.Using the vacuum cleaner is the fastest method and can completely dry out your phone and get it working in thirty minutes. Leave the phone in a bowl or bag of rice overnight the rice would absorb any remaining moisture.
Now test your phone if you still face the issue then you will have to take your phone apart and clean the inside with a towel.If the phone is under warranty then do not do this because it will void the warranty.You will have to send this to repair if it is under warranty.
If you need any more help let me know.
Thank you.
Aug 03, 2009 | Verizon Communications Samsung Alias Cell...
my samsung SGHJ700 fell in water.iwhat should i do?
The following method can be tried when everything else failed and the phone went through the washing machine, fell in salt water or was in dirty water for a long time etc.
Remove as many parts as possible (Sim card, covers, battery)
1. Soak the phone as soon as possible in distilled water to dissolve any dirt, salt, soap etc ( an ultasonic cleaner will be helpful )
2. Repeat step 1 if necessary ( depends how dirty the water was )
3. Soak the phone in Iso Propyl Alcohol ( a very short time in an ultasonic cleaner will be helpful to dissolve the distilled water in the alcohol )
4. Let the phone dry thoroughly,
5. Cross your fingers and switch it on.
May 17, 2009 | Samsung J700 Cellular Phone
300 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
