Tip & How-To about Cell Phones
Cellular Phones: Wet by accident solutions
If your phone was accidentally thrown into water or washed you need to
  1. carefully open the phone by unscrewing the back portion but remove the battery first.
  2. After opening the phone let it air dried. DO NOT expose to heat or direct sunlight. Better if you can just expose it to a open electric fan OR a hand dryer and let the air dry it for several minutes or might take longer for pure air dry let's say 3 to 5days of drying.
  3. After minutes/several days make sure all surfaces are dry, chips, case, keys etc....
  4. if the battery is working okay no need to replace but if not after all the drying better if you get a new battery don't use the old wet one.
  5. put the phone back together (make sure you put all the parts just like before). It should work now....
Cell Phones Logo
water pump leaks
Remove back cover of the washing machine.There are two rubber hoses connected to water pump remove them.and careful detatch live wire from pump motor.There are either 3 or 4 screws connecting the pump onto the washing machine body unscrew them,and the pump should be removed easy then.
Jan 05, 2014 | Estate Top Load Washer
after a blocked pump my wmud 962 wont fill with water, everything else seems to be working fine now but no water, I have checked the obvious water supply etc, does anyone have any suggestions as to what might be the problem, Kind Regards Paul
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Hope you re-connected the exit hose to the right height behind the washer.
Pl click if helped......................
Apr 14, 2013 | Hotpoint Washing Machines
h20 symbol on display of hotpoint wf 860 washing machine
Apr 05, 2013 | Hotpoint Ultima WF860 Front Load Washer
my hotpoint wt540 washer wont fill
Apr 02, 2013 | Washing Machines
no water check supply
136 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
