Tip & How-To about Computers & Internet
How to convert Camera HD Video AVCHD M2TS MTS to Play on iPad
This is a quick tutorial about how to convert AVCHD M2TS MTS to iPad compatible formats so that you can play movie videos from Sony, Panasonic, Canon, JVC , etc HD camcorders on iPad
Before we get started, let's learn some Glossary s about m2ts, MTS, AVCHD and iPad.
AVCHD (Advanced Video Coding High Definition) - is a format for the recording and playback of high definition video, created specifically for high-definition (HD) digital camcorders like Sony, Panasonic, Canon, JVC and Sanyo video camcorders. Generally files with extensions M2TS (after import to computer), MTS(on camcorder).
Note: you can use VLC Media Player to play AVCHD MTS M2TS files
iPad - is a tablet computer developed by Apple Inc. Announced on January 27, 2010, Only support MP3, AAC, WAV, AIFF audio format and MP4, MOV, H.264 Video files
So if you want to import AVCHD files from your HD camcorders to watch on iPad, you must convert AVCHD M2TS MTS to iPad MP4, now let's go to the solution.
What we need is Camera AVCHD(M2TS MTS) to iPad Video Converter - Daniusoft iPad Video Converter; it's a smart iPad Video conversion software that can easily convert almost Video, Audio and HD Video files to iPad with amazing editing function, and it's very easy to use:
1. First save the AVCHD M2TS MTS file from your HD video camera to your computer. then install and run Daniusoft iPad Video Converter, Click the "Add Files" button to browse your computer hard drive and load the HD video files you want to convert to the software.
2.Select "iPad Video MPEG-4 (*.mp4)" as the output format, the default setting will work great, you also can click "Settings" to customize output parameters like resolution ratio (640×480 and 1280*720), bit rate, frame rate, encoder, etc for iPad video.
Note: Daniusoft iPad Video Converer provides some video editing features like Cropping(Cut off the black edge of your video), Clipping(trim any segment of your video to convert), etc, you can DIY your video at will for your iPad.
3. Click "Start" button to convert AVCHD M2TS MTS to iPad.
4.Transfer Video to iPad with iTunes
1. Open iTunes and click "File" to add your MP4 video into iTunes library.
2. Connect iPad with yourcomputer, then iTunes will detect your iPad as a device.
3. Select your iPad on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply", done.
Note: If you don't like to use iTunes to manager your iPad Media files, you can try Daniusoft iTransfer instead – which can copy music video between iPad/iPhone/iPod to computer directly without iTunes.
Tag: Convert AVCHD to iPad, Convert M2TS to iPad, Convert MTS to iPad
Computers & Internet Logo
AVCHD to H.264 converter-Visualize videos on MacBook,iPhone 4 While you have .mts or .m2ts files from AVCHD camcorders of your friends or relatives, you may find it difficult to visualize the AVCHD videos on your iMac, MacBook Pro or iPhone 4. AVCHD is the advanced format for shooting videos in high definition with 1920x1080 or 1440x1080. Most AVCHD camcorders record HD videos in .mts format, while there are some in .m2ts format like Sony HDR-SR5. Sony HDR-CX110, Sony HDR-XR520V and Canon HF S21, Panasonic HDC-TM700K and the like offer AVCHD videos in .mts format. While QuickTime Player does not support playing AVCHD videos, VLC media player may sometimes has problem with AVCHD videos, a quick Mac AVCHD to H.264 converter is needed to make MTS/M2TS videos visible on MacBook and even iPhone 4. Aunsoft MTS/M2TS Converter for Mac is the best AVCHD to H.264 converter, which transcodes videos to Mac compatible MP4 format and deinterlaces AVCHD for playback on Apple computer and iPhone 4. Below is the step-by-step guide for converting AVCHD MTS/M2TS to H.264 on Mac Snow Leopard for you to play HD videos on iPhone 4. Step 1. Load AVCHD videos to Aunsoft MTS/M2TS Converter for Mac. After transferring .mts or .m2ts files from AVCHD camcorder to computer hard drive, run Aunsoft MTS/M2TS Converter for Mac as the best Mac AVCHD converter, and click the "Add" button to load HD 1080p AVCHD videos. Step 2. Choose H.264 format. For Full HD playback on iMac/MacBook Pro, just click the "Format" option and choose HD Video > H.264 HD Video(*.mov) or choose .mp4 output format. The output H.264 videos will play on Mac without problems. If you want to play HD video on iPhone 4, just choose iPhone > iPhone 4 H.264 720P(*.mp4) for converting AVCHD to 720p MP4 for iPhone 4 with H.264 as video codec. Step 3. Convert AVCHD to H.264. Click the convert button under the preview window, and the Mac AVCHD to H.264 converter starts transcoding AVCHD MTS/M2TS to MP4 for playback on Mac OS X and iPhone 4. The Mac AVCHD to H.264 converter deinterlaces and removes interlacing artifacts of the 1080i videos for smooth playback on computer and portable devices. You can then watch the HD videos on MacBook, beamer and iPhone 4.
Aug 03, 2010 | Cell Phones
Best Mac MTS to iPad Converter-Convert AVCHD to MP4 While iPad is the shining tablet computer, you make like to share your videos with your friends, or make the camera videos as promotion to your customers while making a presentation. The most popular camcorders for shooting videos are AVCHD cameras from Sony, JVC, Panasonic, Canon, which output 1080i and 1080p videos in .mts/.m2ts format. However, iPad now does not support HD videos at 1920x1080 or 1440x1080. The maximum resolution supported by iPad is 720p, and iPad does not support the AVCHD format as input. Thus, we need to convert AVCHD to MP4 and downscale 1080i/1080p to 720p for iPad. Aunsoft MTS/M2TS Converter for Mac is the best Mac MTS to iPad converter with built-in profiles for iPad. Here are the simple steps to convert HD MTS to 720p MP4 for iPad on Mac OS X Snow Leopard. Step 1. Load AVCHD camera videos to Aunsoft MTS/M2TS Converter for Mac. Transfer AVCHD camera videos to iMac/MacBook Pro, and run Aunsoft MTS/M2TS Converter for Mac as the Mac MTS to iPad converter. Click the "Add" button to load .mts and .m2ts videos. The converter also supports .m2t file as input. Step 2. Choose iPad 720p output. Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac MTS to iPad converter will convert HD MTS/M2TS videos to 720p MP4 videos for iPad. Step 3. Convert AVCHD to MP4 for iPad. Click the convert button under the preview window, and the conversion from AVCHD MTS/M2TS to MP4 for iPad starts immediately. Wait until the conversion is finished, and connect iPad to iMac/MacBook Pro. Sync 720p MP4 videos to iPad via iTunes, and then you can share the camera videos on iPad, present the promotional video to your clients. Tips: The supported AVCHD camcorders include Sony HDR-FX1, HDR-HC3E, Cyber-shot DSC-HX5V, Cyber-shot TX7, HDR-SR11, HDR-SR12E, HDR-CX110, HDR-CX350V, NXCAM HXR-NX5E, HDR-XR500V, HDR-XR520VE, HDR-TG3, HXR-MC1P, HDR-TG5, HDR-UX1, Canon HF S21, HF S200, HF S22, HF100, HF S11, Panasonic Lumix DMC-G10, Lumix FX33, DMC-LX3, and so on.
Jul 27, 2010 | Cell Phones
1,367 people viewed this tip
David Payne
David Payne
