Tip & How-To about Computers & Internet
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
Computers & Internet Logo
I can find the router on laptop but it wont load on the enternet.
your router is not configured.... the connected light should glow... or the telephone symbol and globe symbol should glow...
to configure the router please follow the link accordingly....
click here for cable internet....
click here for DSL internet....
click here if you are having Embarq, Centurylink, Bell sympatico connection....
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable. Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable. Open internet explorer / Firefox or any of your default web browser. In the address bar type the default gateway address of Belkin router 192.168.2.1 Belkin router setup page (RSP) will be displayed. Login to the page. (password: leave it blank and click submit) On the left side below the "utilities" select firmware update and check the current firmware version of your router. For belkin basic (F7D1301) router the latest firmware is ver.1.00.16 to download the latest firmware for basic router click here... For belkin surf (F7D2301) router (older firmware ver.1.00.10) the latest firmware is ver.1.00.15 to download the latest firmware for surf router click here... For belkin share (F7D3302) router (older firmware ver.1.00.13) the latest firmware is ver.1.00.18 to download the latest firmware for share router click here... For belkin play (F7D4302) router (older firmware ver.1.00.14) the latest firmware is ver.1.00.20 to download the latest firmware for play router click here... For belkin playmax (F7D4301) router (older firmware ver.1.00.15) the latest firmware is ver.1.00.21 to download the latest firmware for playmax router click here... In these updated firmwares all the problems related to various issues have been fixed. download the latest firmware and update it. After updating the firmware click on restore factory defaults found below the "utilities" and restore it. then configure your router according to your internet service provider... For Cable ISPs click here... For embarq and centurylink ISPs click here... For DSL & Satellite ISPs click here.... To configure the wireless part except for play & playmax click here...
Jul 24, 2010 | Audio Players & Recorders
belkin router with a laptop
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
Nov 08, 2008 | Computers & Internet
5,078 people viewed this tip
David Payne
David Payne
