Tip & How-To about Washing Machines
Sears kenmore he2 front load pump filter maintenance
Kenmore HE2 front loader. We had a problem with all the cycle lights blinking. I took that access cover off and found 4 years of lint and muck with a few fabric items in that sump. There is also a second troubleshooting manual taped to the back of the access door. after cleaning the pump filter it worked fine. This should be in the owners manual but its not, they say to call the service guy and be charged an arm and a leg
Washing Machines Logo
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 Plus blinks F-11
Look for the technical brochure. Mine was on the lower kick panel taped inside. I would not take off the back panel first. Maybe the top or the lower front if it is a front loader. It tells you how to do diagnostics and what the codes mean.
Jul 22, 2009 | Kenmore HE2 Plus Front Load Washer
154 people viewed this tip
Top Washing Machines Experts
