Tip & How-To about Refrigerators
DoeIs your electic bill seem to be to high?
I would like to suggest to those that don't have the ability to read the 5 dial electric meter to contact thier electial compnay and have thier meter replaced with a digatal meter. it starts from ooooooooo and starts counting foward when it is plugged in, there meters cost nothing to get the power company to replace them. with the digatal meter you van easily read how much power you use per day or per week or month. Since it has only numbers it makes it much easier to read it also allows you to see if your using more energy than you should be. When you tun on the electric heater you can watch how fats it moves, this helps you determine what is your highest usage appliance in the house. Also if you have a refridgerator or freezer thats going bad it will give you an ideal of weather you need to replace it or not. As the price of electricty continues to rise it will hel you troubleshoot what device is giving you trouble. If you have a dish washer or a garbage disposale that uses a lot of enegry you will know you need to replace it right away. These two devices can burn up energy because the are grounded out to the water pipes and could cause you to use double the electricty you would normaly use due to grounding out to the water pipe. This can also be caused by the water heater you could have a duel element and have one burned out and it would burn up the electricty twice as much. Mosy would use 3000 watts of power together but with one shorted straight to ground only one element would heat up and the other would just ground out and cause the power to burn up at three times it's normal rate. This is a good suggestion for someone who has a high electrial bill, and this is one the electrial companies are not likely to catch. Hope this hepes some folks out there. You can turn off all circut breakers except for the main and read the meter if the meter moves with all other breakers off here are the reasons that could cause this problems. if you live in the country your water well is connected bypassing the main pannel and connecting directly to the meter. so the water meter may not cost you anything. however if the meter still moves you would need to call an electrical as you have a short in the main pannel to ground.
Next turn the breakers on one at a time and see how fast the turn, if you find one that turns faster than the rest this will be your ciruct you have a prloblem with.
There is one exception and thats any 220V breakers that may draw more because of havig two hot wires instead of one. If you turn one on and it really turns fast that circuit could have a problem. The wire could be going to an outside building and buried directly into the dirt. There are may places around the world that will eat threw the insulation and cause the electric wire to have the plastic eaten. This being the case it would not show a short it would ground it to earth and use more electricticity. This advise will help you to read your electic bill and hell you test indivdual ciruits without the help of special tools. I hope this has been of use to many of you who do not know how to to work with electricity but are able to read the numbers in order to know that you have a problem and can show an electrian to save yourself some money.
Refrigerators Logo
battery drain
A wiring diagram of entire vehicle & the
ability to use a half decent volt meter, on the
amp & millamp scale
Pull all fuses,one at a time, until something
indicated the current drain & it stops
Need the meter in series in either battery cable &
ability to see the meter
You have to know what relays need to time out & see
if they do,so don't keep opening the door or you start
the process over.
The battery has to be good also
Not over 5 years old & has to read over 12.6 V when you start
your checking
If this is a 20 year old car,visually check for corroded
fusible links first & don't forget alternator diode leakage
May 23, 2012 | Cars & Trucks
I have a Model SS-51A-PE charger that will not charge an auto battery. Is this normal or is the charger mat functioning ? Don Robinson
If a battery is defective, it will not accept a charge and it is not the fault of the charger. When connected and switched on, with the clamps making solid contact, the amp meter should give you a reading, depending on the state of the battery. To do a quick test on the charger, try it across a headlamp bulb, The bulb should light and the amp meter should read about 5 amps.
May 11, 2011 | Schumacher & Fast Charge Starter Charger
Windows Vista Home Premium not reading driver.
HI
THERE IS A COMPNAY CALLED JACO, THEY MANUFACTURE for General Electric
go to this site , you may have to contact the support centre to get the driver , it may be an older model webacm
http://www.jascoproducts.com/products/pc/GE-Webcams-c14.htm
if this helps, please rate me
Nov 02, 2010 | GE MiniCam Pro HO98756 Webcam
dont know how to use black spur mini digital
If I new the Brand name it would help
on the one I have it plugs into the top with
wire comming out of it.
It's for doing a temp. test
Sep 08, 2009 | Measuring Tools & Sensors
ABS
hi does your reader have the reading ability to read the abs some don,t yates210456
Jul 17, 2008 | 2004 Volkswagen Golf
196 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
