Tip & How-To about Cell Phones
NOW INSTALL FONTS ON N95 8GB 1) Install FontRouter (Fontrouter LT+FontrouterMan)in your memory card, or mass storage in N95 8Gb 2) using the x-plore app, make a folder in phone memory (C:/) named fonts 3) Move the fontrouter.ini and paste in c:\data\fonts 4) edit the fontrouter.ini file with x-plore like this:- search at: Extra font files to be loaded ExtraFontFile=\Data\Fonts\*.* and change it to ;Extra font files to be loaded ExtraFontFile=C:\Data\Fonts\*.* exit and save the file 5) Copy your *.ttf font to c:\data\fonts 6) restart the phone, and there's your new font! if you afterwards want to change your font edit the fontrouter.ini file again and change Enable=1 to 0 restart and change the fonts, then Enable again to 1 and restart and enjoy the new look of the interface.
Cell Phones Logo
i want to changs the fonts for my nokia n70.how to do it.as i had download TTF fonts and fontrouter.dll in my pc.please help me........:)
download this http://www.crazylittleworld.com/n70/egdrsetup.zip
install the application and from there you can create a .gdr format of font that can be used in your n70
once you've created a .gdr font, create a folder on your C:\System\ of your n70..just make sure you have 3rd party file manager to access the folder..then paste your .gdr font to the folder.. C:\System\Fonts\<filename>.gdr\
Hope this'll help
Apr 27, 2011 | Nokia N70 Cellular Phone
how to uninstall fonts in n73
Hey dude to remove fonts from your phone follow these steps
1) Connect your phone via USB to your PC and select the Mass Storage option
2) You will then see your phone as a memory card in My Computer on your PC.
3)Just go to the Resource folder and inside that there will be another folder called Fonts [E:\Resource\Fonts]
4) Just delete that folder called Fonts and then disconnect the phone from the PC and switch it off and then switch it on back. Voila !!!! you will get your old original fonts back!!! :lam: :goldcup:
hay if this not work out just take out our memory card and use a memorycard reader u will also see the resource file there then delete the font folder... thats it ^_^
Jan 14, 2010 | Nokia N73 Cellular Phone
n72 phone
hello there!
Find this app:
FontRouter[1].LT.for.v9.Build20071109.unsigned
1) Install in the memory card.
2) Create a folder in memorycard at data en name it fonts (when there is allready one don't bother, there should b a file there called fontrouter ini
3) make fonts (choose a ttf and copy them 3 times so u have 4 fonts.
4) Rename them in2:
nohindisnr60
nohindissb60
nohinditsb60
S60ZDIGI
Now for the hard part...
5) make sure your cell doesn't use the memorycard (otherwise the mass storage won't work)....
Think about the message setting and change it in2 phone memory...
6) Connect with mass storage and rop the 4 files in the e:data/fonts
7) Unplug and reboot...
8) That's it....
When U want 2 change it, that's even harder.
Because the new fonts R being used by the memorycard, the mass storage won't work anymore. U can't delete the without mass storage....
1) Use the app X-plore and search 4 the frontrouter.ini file in the same folder.
2) Edit the file and change the setting on the 12th row:
enable=1
in2 this:
enable=0
3) save it and exit...
4) Reboot (this will restore your normal font)
5) Now use mass storage (again everything exits on the memorycard) and rename the folder fonts (E:data/fonts) in2 font (so loose the s)
6) Delete the files in there
7) Reboot and that's it.
When u want 2 change them at point 5 U have 2 drop the new ones in there after U deleted the old ones.
Then use X-plore again and edit the ini file and change it back 2:
enable=1
reboot and U have new ones....
Good luck.
Feb 14, 2009 | Nokia N72 Cellular Phone
nokia n95 8gb
how can get a good Nokia new model
Jun 20, 2008 | Nokia N95 Cellular Phone
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
489 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
