Tip & How-To about Cell Phones
REMOVE UNWANTED WORDS FROM PREDICTIVE TEXT Using this trick you can remove sometimes irritating and unwanted words from predictive text. Open xplore or a similar file manager, go to c:\predic\ directory and delete the .dat file or edit it by transfering it to pc, opening it with notepad and editing. NOW SEE THEME ICONS N95 In the new firmware on N95 v20 & v21 & also N95 8GB Nokia has removed the theme icons in the menu, but by using this trick, you will be able to see the theme icons. To do this go to Menu-> Tools Folder-> Utilities Folder-> Device Manager. Here you will see your firmware version and device updated. press D-Pad right button and you'll see no server profiles defined. Press options and select New server profile, and name the server 'name', server id, host adress and user name 'Themes'. Choose your password and leave everything as it is. exit (if it says profile not saved because you didin't do some configurations, try changing connection type to bluetooth) and press Options and start configurations without connection. then go to Menu-> Applcations and you'll see the themes icon! Credits to DoucheBag66.
Cell Phones Logo
how do i remove a word from predictive text on a galaxy s3
HOW TO REMOVE UNWANTED WORDS FROM YOUR GALAXY S3:
Since I could not find any solution on the internet, I had no choice but to figure it out myself. After hrs of messing with my phone, I finally figured it out and wanted to share with those that are still needing answers for this specific issue because I know how annoying it is. So here it is.... ^-^
1) Go to SETTING
2) Select LANGUAGE AND INPUT
3) Tap on the setting LOGO next to SAMSUNG KEYBOARD
4) Select PREDICTIVE TEXT
5) Select MY WORD LIST located at the bottom
6) Tap on the trash LOGO (top right)
7) Select unwanted words
8) Select DELETE (top right)
9) Confirm DELETE
Hope this was helpful!!
Nov 06, 2012 | Samsung Galaxy Siii Gt-i9300 16gb Marble...
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
blackberry texting prediction problem
what exactly is the text problem...here are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do I switch on predictive text
In settings/general/language - make sure that the only language ticked is English - then you can use the *A/a button
Jan 28, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
predictive text problems with my samsung u900
when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
rate me please thanks
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
215 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
