Tip & How-To about Cell Phones
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM part 2
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM .....CONTD....
1. While accessing the default app manager( Uninstaller ). It normally takes a lot of time to scan though the uninstaller files if you have lots of apps already installed. It may even give you a 'memory full unable to remove' error as well. Same could be shown while installing.
Soln. A simple solution to this is browse though using a file explorer and go to
c:\system\install and e:\system\install\ later
You will find the uninstaller files in the above directories.
All you have to do is to create a subdirectory probably as below
c:\system\install\Bypass e:\system\install\Bypass\
Normally in the install folder there would a quite a few apps which you would not be uninstalling/reinstalling frequently(non-frequent updates). All you have to do is mark these files, (These files have an *.sis extention.) cut them and paste them in the Bypass folder we created inside the install folder. You can also delete duplicate unsinstaller files( files of same app but different version-Dont delete anything if youre not sure)
This will make sure that the app manager( Uninstaller ) does not scan through most of the files as they are in the bypass folderand saves time and memory while uninstalling.
You may open the app manager( Uninstaller ) and check how fast it opens scans and uninstalls.
Now in future if you have to remove any application which is in the bypass folder, then cut it from the bypass folder and get itunder install and open the app manager( Uninstaller ) and remove. It takes an effort here but it will save time more often.
2. Boot faster and save memory
Soln. Another one, but be more careful. There is a folder called
c:\system\recogs\ and e:\system\recogs\
These folders contain *.mdl files which normally start on reboot by which reboot is delayed and they consume some RAM memory as well. Now there are certain license manager files and other app files, you need to start while starting the phone, leave them asit is. But you will find other files like quicksheet.mdl etc which is not needed to start on reboot. Such files can be marked and placed into a subdirectory \Bypass under recogs and restart the phone, which will save time and memory as well.
Do it for both c:\ and e:\ carefully.
Later on as required you may bring files from \Bypass to recogs.
Tips- If you get App closed **** error on startup/reboot. This is just the trick for you.
Dont delete anything if youre not sure.
Caution: If you're not sure of something-Dont do it, unless you are experimenting at your own risk.
THE "TO DO" TRICK
Guys i don't know if this works, whether it is true or just a placebo. Find out yourself by trying it.
1.) Change your phone's date to the 01.05.2005
2.) Go to the calendar
3.) Now we need to create two new* to-do's (Options > New entry > To-do)
4.) These two to-do's need to have the following information:
- 1. To-do:
*.Subject:Speed
*.Due date:04.08.2005
*.Priority: High
- 2. To-do:
*.Subject: Qoukie
*.Priority: Low
5.) Confirm the both to-do notes with 'Done', but don't close the calendar application.
6.) Choose: Options > To-do view
7.) Mark 'Speed' as done, after that mark 'Qoukie' as done.
8.) Now you can close the calendar.
9.) Change the phone's date back to the actual day.
Done !
People have claimed that it makes their device faster, so just try it.
THEME EFFECT
Many nokia phones have this feature, turning it off saves RAM and the phone response improves.
CALL LOG
Changing your call log duration to 1 day is also said to improve phone response time
Cell Phones Logo
my mobile`s browser is not responding after pressing the button for many times.... and how can i recover my mobile????? plssssss give some suggestions
It is the default inbuilt browser which does not open or start no matter how many times you restore the device. It is a software/firmware issue ,you need to install the latest firmware (v.10.65) or reinstall the existing firmware (RM-635,v.10.10) to run the browser. Installing the firmware requires PC & nokia pc suite app downloaded in your computer- lot of steps to be followed to install it on nokia2690. However there are lot of third party apps you can download like opera mini 8,UC browser 9.4 etc. -which works much faster & better than that corrupt built in browser that does not even responds .
Jul 05, 2015 | Nokia 2690 - White Silver Unlocked GSM...
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will post some tricks to make your phone faster and also recover precious RAM. 1. MOVE HELP FILES TO MEMORY CARD If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card. Enable CAPS OFF open Xplore or fxplorer and move C/resource/help to E/resource/help. All the apps will find it automatically in the E drive. This trick will increase your phone memory thereby making your phone a little bit faster. 2. DISABLE LIFEBLOG PERMANENTLY first use jbak taskman to kill lifeblogobserver process make sure x-plorer is set to show hidden files then go to c/data/lifeblog/database now delete the lifeblog.dbfile reboot phone now use jbak taskman to kill lifeblogobserverprocess once again! then go to c/data/lifeblog/database select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM. if you want to use lifeblog again go toc/data/lifeblog/database select llifeblog.db file and press 6 and untick hidden and read-only 3. STOP AUTO STARTUP OF APPS ( for a faster boot up) You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process. The info of all the start up apps is stored in c:\private\100059c9\start.dat whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating. When ever you again want to enable the startup apps just remove the .txt extension. You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it. The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want. You can even further boost up your phone start up by renaming files like C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat C:\private\101F99FD\nsmladapterlog???.dat C:\private\101f9a06\nsmldmtree.db C:\private\100056cf\clockapp.dat C:\private\100059a8\nitz.dat C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db C:\private\100012A5\101f8683_ScShortcutEngine.db C:\private\1000850\logo*.* C:\private\100012a5\DBS_10205030_accpolicydb.db C:\private\1000c959\localdata\commondata.D??? C:\private\1000c959\localdata\localdata.D??? To .txt files or simply delete them. Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
May 09, 2010 | Cell Phones
ipad apps
there are 2 different ways to delete an App on iPhone/iPad:
1) - Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner.
that's it.
2) - For devices running iOS 5 and later, there is also another way to do this:
hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-0.jpg ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-2.jpg ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-5.jpg
Jun 28, 2014 | Tablets & eReaders
apps that installed how to remove it
1-Go to app store on your device
2-Search for Uninstaller
3-Install, and run the application
4-Delete desired applications
Feb 09, 2014 | Samsung Computers & Internet
I forgot my Memory Card password, yesterday i updated my phone software and now its asking me the password to access memory card... how to delete it?
hi
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 5310.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
Jan 20, 2010 | Nokia 5310 Cellular Phone
171 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
