Tip & How-To about Cell Phones
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will post some tricks to make your phone faster and also recover precious RAM. 1. MOVE HELP FILES TO MEMORY CARD If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card. Enable CAPS OFF open Xplore or fxplorer and move C/resource/help to E/resource/help. All the apps will find it automatically in the E drive. This trick will increase your phone memory thereby making your phone a little bit faster. 2. DISABLE LIFEBLOG PERMANENTLY first use jbak taskman to kill lifeblogobserver process make sure x-plorer is set to show hidden files then go to c/data/lifeblog/database now delete the lifeblog.dbfile reboot phone now use jbak taskman to kill lifeblogobserverprocess once again! then go to c/data/lifeblog/database select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM. if you want to use lifeblog again go toc/data/lifeblog/database select llifeblog.db file and press 6 and untick hidden and read-only 3. STOP AUTO STARTUP OF APPS ( for a faster boot up) You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process. The info of all the start up apps is stored in c:\private\100059c9\start.dat whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating. When ever you again want to enable the startup apps just remove the .txt extension. You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it. The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want. You can even further boost up your phone start up by renaming files like C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat C:\private\101F99FD\nsmladapterlog???.dat C:\private\101f9a06\nsmldmtree.db C:\private\100056cf\clockapp.dat C:\private\100059a8\nitz.dat C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db C:\private\100012A5\101f8683_ScShortcutEngine.db C:\private\1000850\logo*.* C:\private\100012a5\DBS_10205030_accpolicydb.db C:\private\1000c959\localdata\commondata.D??? C:\private\1000c959\localdata\localdata.D??? To .txt files or simply delete them. Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
Cell Phones Logo
recover deleted message
In this article, you will meet a very good recovery program that will handle all the stress for you. It won't require a technician after all. You can do the job easier and faster.
For better step by step procedures follow these guides:
Step1. Download FoneDog - Android Data Recovery, Install and Launch
Step2. Connect Samsung Galaxy S Note to the computer
Step3. Select Files for Data Extraction
Step4. Select Device Fault Type
Step5. Download Mode
Step6. Retrieve deleted messages by preview and selection
Hope it can help you sooner. Good luck.
Restore Contacts from Broken Samsung Galaxy S Note
Recover Text Messages on Damaged Galaxy phone/tablet
Apr 05, 2013 | Panasonic KX-TG2631 Phone
recover deleted text messages from samsung rugby II
Jan 02, 2013 | Samsung SGH Cell Phones
can i recover all the messages that i deleted from cell phone LG GW300...? if it can, how can i do?
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages from Android.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more..
Jun 03, 2011 | LG GW300 Cell Phone
When should i charge my mobile either fully emptied or when it is partly filled?So that it works for longer period
Well,
It really does not matter. You may charge the phone, whenever, you wish to. Make sure that you do not over charge it as it could cause the battery to die faster.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 04, 2009 | Cell Phones
355 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
