Tip & How-To about Cell Phones
INCREASE PHONE MEMORY BY 5 MB(Only for symbian OS 9.1 rel 3.1 with FP1 Phones )Follow the Steps: 1. Hack your Phone...Disable Platform Security by CapsOff. 2. Open xplore or any file manager . Go to C:/Private/102072c4 folder. You will find a file named"reserved" of size 4.76 MB. 3. Delete it. This reserved file is for FOTA(Firmware over the Air), and we won't need it as we never get any FOTA updates. It does eventually comes back at times.....Most probably when you use your device manager. So at those times you can again delete it. Deleting the file will not effect your Phone......I tested it and using My N82 without any problem. If you want you can make a backup in your Memory Card. Note: For any Loss or Damage to your Phone I shall not be Responsible...But at last this Trick is Safe. Tested and Confirmed working on N73, N80, N81, N82, N95
Cell Phones Logo
my phone memory is 20 mb but it shows only 5 mb???????
Nokia uses Symbian OS on the phone which is loaded in the memory just like computers, you will never get complete memory for use as it reserves the space for you phone OS.
you buy SD card to extend memory on your phone. Your phone supports upto 16 GB
Hope this helps..
Jun 22, 2011 | Nokia 5130 Cellular Phone
how can i change symbisn 3 os in to android
However, that's truly impossible in legal way. Android OS is never compatible with Nokia phones because Nokia phones are made only for Symbian OS.But i have perfect solution here.
Dual Boot is also possible click here to download setup file in pea format
You can upgrade Symbian 60 v 5 of X6 to Symbian X^3, but it will need much more RAM. Nokia X6 has only 128 MB RAM, while Nokia N8, the only Nokia phone that runs with Symbian^3 so far, has 512 MB RAM. Too bad, because to go to Symbian^3 using X6, you have to change RAM too, and it'll cost you lots of money.
RAM Upgrading + OS Upgrading + Brand new X6 costs are greater than buying a Nokia N8.
And Android OS, the 2.2 version is miles better and advanced that Symbian^3, Nokia is always behind of the competition but always give the best and reliable phone.
Dec 15, 2010 | Nokia N95 Smartphone
i cannot unlock my block memory card 4 5130 xpress music
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
Jun 02, 2010 | Nokia 5130 Cellular Phone
180 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
