Tip & How-To about Cell Phones
Noki Codes
NOKIA CODESThere are some useful secret codes for Nokia S60 phones to get system information. Some may be known to you some may be not.
1. *#0000# - Display the software version, the date when the software was built and the phone model. In some cases, the phone model is not the one used by marketing. It is the internal model used inside Nokia. For example, RM-36 is the internal name of Nokia 6680.
2. *#06# - Display IMEI (International Mobile Equipment Identify) of your phone.
3. *#2820# (*#BTA0#) - Display the Bluetooth device address of your phone.
4. *#62209526# (*#MAC0WLAN) - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
5. *#7370# (*#RES0#)- Reset your phone to the default factory settings. Usually you will need this code when you want to reset your phone back to the same condition when you got it for the first time. When the phone ask for security code, the default one is12345.
Warning: Before you do reset the phone, make sure that you don't have important data. Your data on the phone memory will be lost once you reset it.
6. *#92702689# (*#war0anty#) - Display the life timer information of your S60 phone, i.e. the total time of phone call (in minutes). Some users have asked how to reset this timer; as far as I know the only way to reset it is by flashing the phone.
7. *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.
8.Format-There is another key combination which is used to format the phone. It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then pressing and holding the Call key (Green key) + * key + 3 key + power button till you see the timezone menu and then release them.
Formatting should be done only in extreme situations.
Cell Phones Logo
my imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Nokia Default Codes Most Nokia phones have the same default codes.The default code is entered for the first time on a new Nokia phone and it won't be accepted if the default code has been changed by its owner. Here are some default codes; Security Code: 12345 Phone Lock Code: 12345 Standard Bluetooth Pairing Codes: 0000 Nokia Secret Codes There are a lot of secret codes on the Nokia phone and I'm sure you are aware of it or even know some of it. The listed codes below may NOT work for all the Nokia phones or it is restricted to some Nokia phones but you can try it on your phone to find out. Here are some of the useful codes: #pw+1234567890+1# : Information about Provider Lock Status/Sim Restrictions. #pw+1234567890+2# : Information about Network Lock Status. #pw+1234567890+3# : Information about Country Lock Status. #pw+1234567890+4# : Information about Sim Card Lock Status. *#06# : Imei number (International Mobile Equipment Identity) or serial no. *#7780# : To reset the phone to factory settings. *#7328748263373738# : To reset the phone's security code. *#92702689# : Details about the phone: Serial no, month and date produced, the date the phone was purchased, date of last repair (0000 if not repaired at all). *#0000# : software version. *2820# : To add Bluetooth Device. *#7370# : To reformat the phone or Hard Reset (usually for Symbian phones). *#99# : GPRS Speed dial Code. *#746025625# : Details about the Sim Clock Allowed Status. *#7370925538# : To Reset Wallet Code (usually for S60 phones) *#3925538# : To Delete All Content in Wallet (if it ask for the phone lock code enter your phone lock or the default phone lock code). *#9999# : Details about the software version if *#0000# doesn't work. *#2640# : To display the Security Code in use. *#73# : To Reset the phone's time and also the game scores. *#7760# : To display the Manufacturer code. *#8110# : Details about the Software Version for Nokia 8110. *3370# : To activate Enhanced Full Rate codec (EFR) (which means your phone will use the best soud quality but the talk time is reduced to 5%). #3370# : To deactivate the EFR. *#4720# : To activate Half Rate codec (which means your phone will use the lowest quality sound but you would get 30% more of talk time). *#67705646# : To remove Operator Logo for Nokia 3110 and Nokia 3330. *#43#: To view the Call Waiting Status on the phone. *#30# : Enable to view the private number. *#21# : To check numbers that All Calls are diverted to on the phone. *#61# : To check the numbers that On No Reply calls are diverted to. *#62# : To check Divert If Unreachable/No Service calls are diverted to on the phone. *#67# : To check that On Busy Class are diverted to.
you may visit some nokia mobile sites........
Mar 15, 2010 | Rock & Ice Climbing
sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
i have forgotten my lock code in my nokia n80 mobile phone. pls help me 2 solve my problem. thankz...
Hello, try this, it might work:
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Other secrets :http://gleez.com/articles/did-you-know/nokia-secret-codes
Also look at this thread -> http://www.fixya.com/support/t450511-nokia_n80_phone_lock_code It might be handy ;)
Oct 19, 2009 | Nokia N800 Tablet PC
263 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
