Tip & How-To about Cell Phones
REMOVE CAMERA SHUTTER SOUNDWorking on: N73ME, 5700, 6120C, N95-1, N81 8GB, N78 1. Turn on "Caps Off" 2. Open X-plore 3. Goto "Z:\Private\10202be9\101F8809.txt" 4. Copy the file to "C:\Private\10202be9\101F8809.txt" 5. Edit the file "101F8809.txt" 6. At the end of the file, u will find the line Code: 0x7 int 10 cap_rd=alwayspass cap_wr=alwaysfail 7. Change it to Code: 0x7 int 00 cap_rd=alwayspass cap_wr=alwaysfail 8. Save the file and exit X-plore 9. Turn on "Caps On" 10. Turn off "Warning tones" in ur profile 11. Restart the phone. No more sounds in camera
Cell Phones Logo
press shutter releas button for error are coming ,wat is the Problem
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR ' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR ' with a different Canon lens attached, then the camera should be serviced.
Nov 17, 2010 | Nikon D40x Digital Camera
lock code on my nokia n78 how to unlock
Try doing the hard reset:
To hard reset/format Nokia N78 (all data will be lost), follow the below mentioned steps: 1. Turn off the mobile phone.
2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these three buttons, press the power button to switch on the device.
4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
www.usedcellphoneshop.com
May 19, 2010 | Nokia N78 Smartphone
nokia n78 will not turn on
hi thanks for using fixya!
Try the following options.
1. Turn off your mobile unit
2. Remove the sim card
3. Remove the battery
After you do all those, install them back again, and try to turn on the power. If you are experiencing the same problem. I suggest you should bring your phone to a service center to further check the error.
Regards!
May 03, 2009 | Nokia N78 Smartphone
keep getting ERR99 when i take my first shot after switching on.
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Jan 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
i have error 99 in my camera canon 400d
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Jul 31, 2007 | Canon Digital Rebel / EOS-300D Digital...
157 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
