Tip & How-To about Cell Phones
CHANGE THE DEFAULT NAMES OF MENU ICONS IN S60V3 1)Keep the app in the top left corner of your menu screen. Select any folder and press options so that the option menu is just open. http://i45.tinypic.com/2e1ua0o.jpg http://i47.tinypic.com/2wbvzw4.jpg 2)Now without pressing any button or exiting the option menu press the power button (the on/off button) and put your mobile in offline mode http://i50.tinypic.com/2z5op36.jpg http://i50.tinypic.com/34f0jeu.jpg 3)the highlight cursor will select on the first icon with the option menu still open http://i48.tinypic.com/25sbq1l.jpg http://i47.tinypic.com/35dcoew.jpg 4)you will se a new option RENAME in the option menu now select the rename option and rename to what ever you want 5)You can use various symbol also copy any symbol from text file and paste it using the copy paste function as usual. RESET PASSWORD OF MEMORY CARD (ONLY FOR PHONES WITH REMOTE LOCK OPTION) If you forget your memory card password you can unlock it by using this trick, You can activate this feature from Tools | Settings | Security | Phone and SIM | Allow remote lock menu. The password of your memory card will be your remote lock message. Define a remote lock password. Lock it by sending a message from another phone to your phone written as password LOCK and then unlock it by sending parsword UNLOCK Now your memory card will be unlocked. REMOVING THEMES Removing themes is a common problem in s60v3 phones. Here's how its done Do CAPS OFF Open Xplore or any other file manager. Go to C or E/private/10207114/import. Every folder here contains 3 or 4 theme files(*.ini, *.mbm, *.mif, *.skn). If the folders don't denote the name of the theme, open the *.skn file in hex viewer and you will see the name of the theme. To remove the theme just delete the 4 files of the theme(and not the folder itself) which you want to delete. DONE You can do the same via mass storage connecting the phone or mmc to computer and don't forget to enable view hidden files.  http://img200.imageshack.us/img200/8694/443762657498dd3b764d59f.png http://img21.imageshack.us/img21/2449/turani.gif
Cell Phones Logo
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
how do I keep my sgii note from downloading apps when I restart it
First, goto google play store.
Then, press the menu button in the top left hand corner, which will open the left hand menu.
Select settings and where it says auto-update apps, select do not autoupdate apps.
Sep 06, 2014 | Cell Phones
Top left corner of screen completly black everything else is fine. Please help determining problem?
hi,
i think ur tvs closed caption option is ON. make it of by the following procedure .
1.press menu and select setup
2. in the setup menu select cc.
3.in the cc menu select mode and change it to off.
4. then press ok. exit menu and and watch the corner.
if nothing happened ,
do the above mensioned first two setup and
3. in the cc menu select cc reset and then press ok
ok,
Dec 15, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
347 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
