Tip & How-To about Computers & Internet
BOOST PERFORMANCE OF YOUR PC
  • Right click to my computer
  • go to advanced
  • go to performance setting
  • go to advanced
  • go to virtual memory
  • change keep the initial size same as maximam
Computers & Internet Logo
How can I increase the memory for this computer
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
I computer is slow and a message that my virtual memory is low
1. Click Start, right-click My Computer, and then click Properties.
2. In the System Properties dialog box, click the Advanced tab.
3. In the Performance pane, click Settings.
4. In the Performance Options dialog box, click the Advanced tab.
5. In the Virtual memory pane, click Change.
6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
Click OK and close .
Oct 11, 2009 | E-Machines eMachines Desktop PC
virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Can't run Brain Play Jumpstart Spanish from Scholastic
How to increase Virtual Memory?
In Windows XP
7.Click Set
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
May 13, 2009 | Vivendi Jumpstart Spanish (72019) for PC,...
180 people viewed this tip
David Payne
David Payne
