Tip & How-To about Computers & Internet
How to replace LCD screen display in the laptop ?
Replacing the Laptop screen will help us to restore our computer back sometimes... Spare LCD screen are available in market at less cost compared to buying a new laptop, as because of the screen has damaged in our laptop...
click here to know how....
Computers & Internet Logo
sceptre 32 inch tv takes about 3 min. to power on and sometimes don't power on at all
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 14, 2016 | Sceptre X322bv-hd 32" 720p Hd Lcd...
How do I fix my Philips plasma TV?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
After the replacement of power board, Plasma display need a voltage adjustment. Va & VS voltage adjustment is very critical to all plasma displays. You can get details about this adjustments, by the site linked above.
Nov 24, 2015 | Philips Televison & Video
The lights come on and the second board lights up in the Back but the screen stays black. I read somewhere that the power board sometimes goes out but I suspect something else. Any answers?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
May 19, 2015 | LG 42LG70 42 in. LCD HDTV
computer will boot but screen is completely black brharris70@gmail.com
try to connect to an external monitor, if it works, then you need to replace the LCD screen
Feb 02, 2011 | Toshiba Computers & Internet
my AOC LCD monitor was broken,their are posible for the replace for the screen?it is available in the market?
yes it's posible to replace screen but thing is it will cost you the allmost 75% price of LCD
May 05, 2010 | AOC LM 520A 15" LCD Monitor
207 people viewed this tip
David Payne
David Payne
