Tip & How-To about Car Audio & Video
No sound from my car amp, wired up right won't come on
Installed my Audiobahn A2300HCX amp to my kenwood head unit. Just got this amp off ebay, ran all my wires for my amp. Finally it was time to hear it BUMP, but nothing... As i calmed down form woundering bout if i got ripped off on ebay, i recheck all my wires, reground the wire to an other spot, check my fuse on amp, and inline fuse from power wire off battery, AGAIN NOTHING.......... FINALLY had an idea bout jumping a wire from the power terminal (off the amp) to the remote terminal (off the amp), AND BOOOOM my amp kicked on... TURNS out it was my remote wire off the head unit off the harness was bad never hooked up an amp to it before. BUT dont leave it that way the amp will stay on all the time i only did it to see if it works. THANK GOD IT WASNT THE AMP
Car Audio & Video Logo
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
bass knob for audiobahn a2300hcx, where can i get one
possibly try ebay maybe! i think the ABR is the same, most knobs on amps are the same unless smaller!
May 05, 2010 | Car Audio & Video
two A2300HCX amp on ONE AW1508X is it possible? Over doing it?
Nothing is too much but surely it's worse and destructive if you don't have enough. If you can bridge the amp to power a single sub that would be the best. So if money is not a factor then having too much will only be destructive once you set it more than it's limits, you'll know when that happens. It will be very annoying or really quiet.
Apr 30, 2010 | AudioBahn AW1508X Car Subwoofer
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A1500HCT in Protection Mode
try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
991 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
