Tip & How-To about Linksys Wireless-G WRT54G Router
List of the hidden webpages in the WRT54G 4.20.8 .. and higher
Following is the list of some hidden Web pagtes of WRT54G [ Firmware 4.20.8 or higher ]
http://192.168.1.1/SysInfo.htm (list of MAC adresses)
http://192.168.1.1/SysInfo1.htm (RAM , Flash and processor)
http://192.168.1.1/Cysaja.asp (Router statistics)
http://192.168.1.1/wlaninfo.htm (802.11 settings)
Courtesy : http://linksysfirmwares.googlepages.com
Linksys Wireless-G WRT54G Router Logo
I'm using MAC filtering on my EOC-2610 firmware 1.2.4. ''Allow...''. I saw 1 unidentified MAC adress in the clientlist. It was an user which was allowed with his laptop but also logged into the EOC-2610 with his Iphone after just entering the WEP key. The Iphon's MAC adress is not in the MAC list. How is that possible?
To be honest, it sounds like, though he put in the WEP key, his phone was actually logged in via 3g rather than 803.11
Just because you set it up to connect using wireless routing doesn't mean that it does. Many phones are pre programmed to favor their 3g or 4g networks rather than 803.11.
May 04, 2011 | EnGenius EOC-2610 802.11b/g Wireless...
how do i renew the ip adress for my linksys router ?
Goto your web browser.
Enter 192.168.1.1 and put admin for both username and password.
The admin screen for your router should have a MAC address clone feature. If you enter the MAC address (which is found on the main page of the admin screen) and change the last two boxes, it will renew the IP address. Don't change the first 4 of the mac. When putting different numbers in the last two, it has to be hex (1-8 for first digit and a-f on the second digit).
Hope this helps,
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
with Linksys wrt54g v6 I cannot access the setup page - I get window that says management mode firmware upgrade
  If the Power LED on your Linksys router is blinking, this means the firmware is corrupted. Since the firmware is corrupted, you won’t be able to access the web-based set up page of the router. Instead, you will be using tftp.exe to update the firmware. We recommend that you perform the following procedure in a Windows-based computer.
Downloading the Firmware
Follow the procedure here:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3703&p_created=1151556377&p_sid=7FfWNnGj&p_accessibility=0&p_redirect=&p_lva=19073&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mjc3OSwyNzc5JnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cmVzZXR0aW5nIHRoZSByb3V0ZXI*&p_li=&p_topview=1
Aug 26, 2009 | Linksys Wireless-G WRT54G Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
536 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
