Tip & How-To about Computers & Internet
How to Install Windows XP on Your Preinstalled Windows Vista Computer
The question I am asked most often is “How do I install a dual-boot with Windows XP on my new Windows Vista computer?” The answer is that it’s not that difficult, it’s just very time consuming, and you need to own a copy of Windows XP.
Note that you should not attempt this if you aren’t ready to troubleshoot any problems that might occur.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we’ll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don’t just use the default. I chose roughly 10gb by entering 10000 into the amount.
The next step might be confusing, because we need to change the cd-rom drive that’s invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it’s already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn’t the end of the world, but it’s not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we’ll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it’s easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you’d like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can’t do the next step until we reboot. (you can try, but it won’t work)
So we’ve come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like “XP”. It would be wise to name the C: drive to “Vista” at this point as well.
Now you’ll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like “Hit Esc for boot menu” you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don’t try and install onto your Vista partition! See how much cleaner it is now that we’ve labeled each partition distinctly?
We’ll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we’ll need to use the VistaBootPro utility to restore the Vista boot loader.
Update: VistaBootPro is no longer free, but you can still download the free version.
During the install you’ll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the “Windows Vista Bootloader” and then “All Drives” radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you’ll only be able to boot into Vista, but we’ll fix that. Instead of manually doing the work, we’ll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the “Manage OS Entries” tab and then click in the textbox for Rename OS Entry, and name it something useful like “Windows XP” or “The Windows That Works”
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying “unable to find ntldr” when trying to boot XP, you’ll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can’t find the files there, you can find them in the i386 folder on your XP install cd
This is a critical piece of information: Windows XP will be installed on the D: drive, even in Windows XP… so you’ll need to keep that in mind when tweaking your system.
You can share information between the drives, but I wouldn’t recommend messing with the other operating system’s partition too much… it might get angry and bite you. Or screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition “Data”.
Computers & Internet Logo
is it possible to install windows xp 2 when there is already windows 7 is installed.i want to install both os running in my dell vostro 1015 laptop,
Yes you will have to format your drive and remove partitions, then create new partitions and add a boot up option menu. Then when you power on your computer it will ask if you want to boot Windows 7, or Windows XP. You will have to have both copies of Windows also your restore partition can't do this.
Aug 12, 2011 | Dell Vostro 1510 Laptop
dual boot
Hi abc_19 ,
Before I answer your question , let me tell you that you need to back up your data.Also, make sure that your system hardware supports Vista.
You also need to have genuine windows XP and windows Vista disks handy with you.
1. Partition your hard drive. In Windows XP, using the $50 PartitionMagic or (according to one of our readers) the free GParted Live CD, create a new "primary" partition to install Vista on. Make it at least 20 gigabytes in size.
2. Install Vista on the new partition. Pop in the Vista CD and point it to your newly-created partition as the installation destination. Installation will restart your machine at various points.
3. Choose your operating system on boot. Once Vista is installed on your newly-created partition, on boot up, you'll get a choice to start XP or Vista. The default is Vista. However, this can be changed using Vista's boot manager.
When you're up and running with Windows Vista, be sure to check our our Vista upgrade power tips.
The original article appears below for posterity, and it's still got relevant screenshots and other info for those of you looking to dual-boot XP and Vista.
http://www.youtube.com/watch?v=nNZi5fLpqus
(WATCH THE ABOVE VIDEO FOR MORE HELP)
Cheers :-)
Jun 05, 2008 | Dell Latitude D600 Notebook
win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
156 people viewed this tip
David Payne
David Payne
