Tip & How-To about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Sciphone i68 AT&T GPRS & MMS Internet Settings
Thanks to the author, follow these steps:
GO TO SERVICES AND FOLLOW THE FOLLOWING:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT ANY OF THE PROFILES LISTED(EXAMPLE CHINA MOBILE)
A SCREEN SHOWS ACCOUNT NAME, APN, USER NAME AND MORE
EDIT ACCOUNT NAME TO AT&T, GO ON OPTIONS AND PRESS DONE
EDIT APN EDIT TO wap.cingular (lower case), GO ON OPTIONS AND PRESS DONE.
EDIT USER NAME TO WAP@CINGULARGPRS.COM (UPPER CASE) AND PRESS DONE.
EDIT PASSWORD TO CINGULAR1 (UPPER CASE) AND PRESS DONE.
EDIT AUTH. TYPE TO SECURE.
SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
GO BACK A COUPLE OF TIMES UNTIL THE OPTION WAP AND DATA SUPPORT APPEARS AGAIN
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT SIM 1 OR SIM 2 (OTHER SIM NEEDS SETUP IF BEING USED ALSO)
IF AT&T APPEARS SELECT IT, IF NOT EDIT ANY PROFILE AND RENAME IT AT&T.
SELECT EDIT PROFILE
GO ON HOMEPAGE AND CHANGE IT TO http://device.home lower case)
GO ON DATA ACCOUNT, THAN GPRS, AND SELECT AT&T.
GO ON CONNECTION TYPE, ITSHOULD READ HTTP, PRESS ON IT, SELECT HTTP
ENTER PROXY ADDRESS 066.209.011.032
ENTER PROXY PORT 8080
PRESS OK THAN SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
SELECT ACTIVATE PROFILE( ATT WILL APPEAR AS SELECTED)
THE PHONE IS READY. GO TO SERVICES AND SELECT HOMEPAGE FOR INTERNET.
MMS SETTINGS
1. Select Messages
2. Select MMS
3. Select MMS Settings
4. Select Edit Profile
5. Select any profile
6. Choose Edit Profile
7. Edit Rename Profile to AT&T MMS
8. Press Options
9. Press Done or OK
10. Edit Home Page to http://mmsc.cingular.com
11. Press Options
12. Press Done or OK
13. Select ATT MMS and press OK
14.Edit Connection Type to HTTP
15.The IP address is 066.209.011.032 and the port number is 8080 and press OK
16.Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
17. Press Options
18. Press Done or OK
19.Edit the Password to CINGULAR1 (UPPERCASE)
20. Press Options
21. Press Done or OK
22. Press Done
23. When prompted to SAVE please select Yes
24. Select Activate Profile and yes.
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
how can i easily open the GPRS on my china mobile E71 phone?
I think enabling internet in your China mobile you have activate the GPRS and I think currently Airtel is best for GPRS connection I also use this same internet connection think you also use same GPRS connection, use following steps for activating GPRS
Use following steps:
• Go to "services" -> Data Account -> GPRS.
• Select empty account
• Then edit the account as following.
Open MOBILE OFFICE - Account Name - APN - type airtelgprs.com
o user name
o Password
o Auth. Type
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | BenQ-Siemens Benq E71 Mobile Phone Cell...
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
KA08 Mini
You have to edit the profiles for yourself.
Go to Services/Data account/GPRS, choose one of the profiles you can find there and then edit it (you get all the informations you need from your phone provider)
Jul 04, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to get internet on i9 phone im with fido
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: internet.fido.ca
user: fido
password: fido
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>FidoINT
Connection type: HTTP
user: fido
password: fido
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
Feb 22, 2009 | Dual Electronics CECT P168 Cellular Phone
1,393 people viewed this tip
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
