Tip & How-To about Computers & Internet
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
Computers & Internet Logo
AVG 8.5 problem encountered - avgwdsvc.exe
Reinstalling is the best option, as there are no fixes on this problem. It will take you 3 minutes.
Jul 21, 2009 | N Software AVG 2YR AVG ANTI-VIRUS V8.5 WIN...
Error: Action failed for file avgwdsvc.exe: starting service.
open services.msc from run window and then find avgwdsvc.exe. right click and select properties then check the disabled checkbox. Apply and get out of services.msc. now try to install the new version of avg.
May 16, 2009 | Computers & Internet
I purchased the AVG Anti-virus & anti- spyware cd
Installing AVG might not be able to solve your spyware problem.
You could try downloading free mbam:
http://download.bleepingcomputer.com/malwarebytes/mbam-setup.exe
Double-click and install it. Then run it. Click the Scan button, It will detect and remove the Spyware Guard 2008
After clicking on OK button for scan is complete, you need to click the Remove Selected button when the malwares are listed.
Let the computer reboot if mbam needs that.
Then try installing AVG.
Just in case, you could also try booting from the AVG CD. If it's bootable, it will be able to scan your computer without the need to boot in to windows. Try it too.
HTH
Jan 04, 2009 | Computers & Internet
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Jun 09, 2008 | Computers & Internet
234 people viewed this tip
David Payne
David Payne
