Tip & How-To about Office Equipment & Supplies
What is a drum cartridge?
A drum cartridge is the rotating drum that puts the toner onto your copy's! You would need this to make copy's and after its empty, it would need replacing.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
how to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
What is the drum cartridge?
Apr 22, 2010 | Konica Minolta Magicolor 2530 DL Laser...
how do i manually rotate cartridge carosel
You don't want to rotate the toner cartridges, you need to get a new Drum Cartridge assembly.
When you get that, it will have detailed directions, but you'll end up opening the top of the printer and pulling the drum straight up.
This is a different component than a toner cartridge. The toner carts are the supply of new toner. The drum cart collects excess toner during the printing process, and when it's full you need to get a new (empty) one.
If you connect to your printer's web interface it will have a link for "order supplies" that will take you right to the dell.com page for it.
Post a comment back if you need me to get the URL, and I'll grab it from my printer when I get home tonight.
Sep 02, 2009 | Dell 3010cn Laser Printer
It will not copy after I emptied the waste container.
There really isn't enough information given to give a proper solution. This copier has the drum light come on steady or flashing to indicate the waste toner needs to be removed. I don't know if you're a technician or not but lay people have emptied the toner cartridge instead of removing the drum, removing the cap on top of the drum, emptying the waste toner , replacing the cap on the drum, then putting the drum back into the copier. I've never had a copier keep the drum light on after doing this.
Let me know if you need more help.
Nov 18, 2008 | Canon NP 7130 Black and White Copier
Xerox XD130df empties toner back into cartridge overflow
that really sounds like a defective toner cartridge. Either there was no developer in the cartridge or the metering blade that limits the ammount that gets onto the roller is bad.
Has to be the toner cartridge. Unfortunatly that may have also ruined the drum and cleaner within the drum cartridge. Return them for an exchange.
The reason it is running and running is that it is trying to read a patch that is developed on the drum and add toner to make a dark enough copy. And that definatly is not happening.
If the laser was not turning on, the machine would come up with a L something code. Besides if the laser was not comming on, the paged would be blank.
You can pretty much eliminate everything but the toner cartridge.
Sep 22, 2008 | Xerox WorkCentre XD130DF Laser Printer
128 people viewed this tip
jasbo
jasbo
