Tip & How-To about Video Game Consoles & Games
How to fix the 3 red ring of death on xbox360
  1. How to fix the 3rrod in simple easy steps
  • first u will have to take the covering off witch is simple you can find the video how in the link right here http://www.youtube.com/watch?v=Vy2pVygQPXM
  • Then u will have to take the screws off the metel covering and to do that you will have to use a tork screw driver witch can be bought a radio shack
  • when u get the screws out then u dissconect the 2 cords from the disk drivve and the cord from the fan and take them out and also take out the dust fan
  • once you have thoes dissconnected and pulled out then you can take out the board out of the metel covering
  • once you have it out take a air compresser or bottled are and carfully blow off the exsesive dust and make sure it is clean
  • then turn the board to it back were u can see the X clamp and four little chips with what it looks like mini sponges aka heat esorbers
  • take them off and clean of the excess stuff on the 4 chips with goo gone and viniger with a cue tip be carful
  • then take artic rado five thermel paste and put a reall really thin layer and each one
  • then u have to have eight pennies and make 4 sets of two pennies
  • you take the 2 pennies and wrap them in electrical tape
  • then u put them on the four spots of the board and make sure they stay
  • then you take the board and put it back in the metel caseing if the pennies fall off acidently its ok it happens just make sure u put them back on so they will stick
  • when u get the board back in the case conenct the fan and disk drive and put the dust cover back in and make sure it is all properly back in there
  • then out the screws back in and put the covering back on
  • Then it should work like a xbox 360 again
  • ITEMS YOU WILL NEED
  • tork screw driver
  • goo gone
  • viniger
  • cue tip
  • flat head screwdriver
  • bottle air or air compresser
  • cloth for cleaning
  • artic radio five or any thermal paste
  • 8 pennies
  • electrical tape
THANKS FOR READING THIS HOPE IT WORKS
micheal kirchner 15
Video Game Consoles & Games Logo
three red lights flashing. What to do?
3rrod is a common fault with the 360, it says that its a "general
hardware failure" which could mean anything really. In truth its the lead
free solder that cracks with so much heat and as a result the Xbox 360
fails causing the 3rrod (3 red rings of death).
run a search on the net or youtube for 3rrod guides, there are a few free ones available
You will need to get a 3rrod repair kit or get someone to fix it for you,
there are guides available on the internet. I'm in the middle of
producing one right now that I will make available free of charge for all
fixya members.
xboxrepairkit
Oct 09, 2009 | Microsoft Xbox 360 Elite Console
it starts to flicker while you play
This sounds like the lead free solder is failing and will eventually go to 3rrod or e74
3rrod or e74 are common faults with the 360, it says that its a "general
fixya members.
xboxrepairkit
Oct 07, 2009 | Microsoft Xbox 360 Console
my red death three ring light is not working on my xbox 360
3rrod is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet. Im in the middle of producing one right now that i will make available free of charge for all fixya
members.
www.xboxrepairkit.co.uk
Sep 26, 2009 | Microsoft Xbox 360 Console
three rings of death
this ones kinda an ify problem. ive had had it and just blue all of the dust out of the power converter and the consle and it worked. for now. but the three rings mostly mean a hardware failler. :( so sad
Sep 24, 2009 | Microsoft Xbox 360 Console
My xbox has an E74 error and i dont kno what to do to fix it
youtube has several instruction videos on how to fix your problem. Go to youtube.com and do a search for xbox red ring of death.
198 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
