Tip & How-To about ATI RADEON™ HD 2600 XT, Graphic Card
ATI Radeon HD driver installation error: product identification error
Hello there.
I am an ATI Radeon customer myself (I own an ATI Radeon HD 2600XT) and there's a problem that I've faced for a long long time and have finally found the solution.
If you have this driver or any other ATI Radeon HD 2600/3600 series you might have noticed already that when trying to install the drivers (both out of the CD or the downloaded once) the driver-installation program does NOT identify that you have that exact model. Thus, causing you problems of not being able to play high quality PC Games and/or Video Codecs problems.
I was astonished, that's an error from ATI side, what should I do?
Well thank god ATI put an eye for that problem and they finally published a solution to it, a hotfix.
How to apply the hotfix and finally enjoy the potentials of this amazing Video Card?
Go here http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
Select your operation system. (For me, I have Windows XP Professional, so I would click Catalyst 10.4 Hotfix for Windows XP PRofessional and Home Edition.)
And by clicking there it prompts you to download the hotfix that includes the driver and ATI Catalyst.
Install it, and you're good to go.
Enjoy.
ATI RADEON™ HD 2600 XT, Graphic Card Logo
hp 7900 usp make problems when i connect ati radeon hd 5450
your hp only has a 350 watt power supply, you need at least 400 watt, preferably 450 - 500 watt.
Jul 19, 2013 | Computers & Internet
Is that the ATI Radeon HD 4570 GPU Compatible with the ASPIRE 5535 Laptop
Have you tried applying a little heat to your original GPU to see if it works. Wrap the motherboard in some aluminum foil and leave the GPU Video Card exposed then take a Hair Blow Dryer and put it on high and apply heat to it for about a minute or two using a sweeping motion (not sitting in the same place). Take something like a pencil with an eraser and push down on the edges and in the middle of the GPU to help it reseat itself. Repeat the steps for another time or two then remove the aluminum foil and let it cool off before putting the board back into the laptop. You might be surprised because I've done it lots of times to bring a bad video back card back to life.
May 11, 2012 | Computers & Internet
I can not find ATI Mobility Radeon HD 5470 Problem with the Samsung PC Laptops I can not find ATI Mobility Radeon HD 5470 on my Laptop Samsung NP-R525-JT06 (Windows 7)
Hello
you should download the latest driver for ATI from the main website of ATI,you can try that (it(s from Dell server and tis should work with you) 130 MB:
http://ftp.us.dell.com/video/R272410.exe
May 25, 2011 | Computers & Internet
Installed my VisionTek HD 5570 in my fairly new HP Windows 7 PC. Using DVI connection, the Starting Windows logo comes on, but then locks. I can hear the system continue to boot, but don't know why it's locking. Could it be that I've not completely removed the on-board NVIDIA adapters, even though I've disable it?
I recommend that try to download the updated driver for the Video Card because I've encountered that kind of problem with my Sapphire ATI Radeon 6870, I've just downloaded the updated driver through the ATI website.
Hope I've help you somehow. =)
AnEspera
Apr 21, 2011 | VisionTek ATI RADEON HD 5570 1 GB SFF...
1,987 people viewed this tip
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
