Tip & How-To about Computers & Internet
Simplified Windows 7 File Search - XP Style Results
Many of us are still a bit confused with the Windows 7 File Search and the somewhat overwhelming and often confusing 'Help Files". I hope this makes life easier.
There's a lot of things you can do with Windows 7 Search, but in reality, all that most of us want is to do a simple search for "?' files without this confusion. Something akin to XP. Well, here it is, simplified in a simple way by a simple person, me :- P
Using your mouse: -
1. Left click on the "Start" icon,
2. Type in your search in the search box, eg, empire, eny*, joy*.inf, *.PDF etc. Much the same as you would with XP.
3. Click on the magnifying glass "See more results", then either
4.a Left click on "Computer" to search entire system, or
4.b "Custom" to search specific folders in a similar way to XP.
DONE :-)
If you want to further narrow down your search parameters, click on the top right where your search phrase is for more options.
If Search does not work, check to see if the service is enabled: -
1. Right click on "Computer" (either on Desktop or within Start Icon)
2. Left click on "Manage"
3. Left click on the "Services and Applications" pointer.
4. Left click on "Services"
5. In the right panel, scroll down till you see "Windows Search" and: -
6.a Right click on "Windows Search" (or double click to skip next * step)
6.b *Left Click on "Properties", then: -
7. Change the Startup Type to "Manual" then click on "Apply" then "OK".
8. It's not necessary, but restart Windows anyway.
Some System/Hidden files won't be shown unless previously enabled using a separate process.
Computers & Internet Logo
Where do I find the AVG program I have to open to find OPTIONS and REACTIVATE?
if progamme is installed then just go to windows drive-program files-avg
for windows 7 it can be program files 86 for different os bits
Sep 12, 2014 | Computers & Internet
MSI K9VGM-V ms 7253 v1 can support windows 7 os
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Aug 15, 2012 | MSI K9VGM-V Motherboard
Need help with missing libgimpui-2.0-0.dll file
The problem is you didn't completely uninstall Gimp before you installed it again so the Gimp install file got confused when it found some residual files or registry keys from a previous install and thus it skipped installing some files (libgimpui-2.0-0.dll was one of them for sure) You need to completely uninstall Gimp before you can install it again properly. Get a copy of Revo uninstaller from the link below and use it to uninstall Gimp for you. You should be good to go after that.
Revo Uninstaller 1.94 Link:
http://majorgeeks.com/Revo_Uninstaller_d5706.html
Jun 14, 2012 | Computers & Internet
any chance of a driver for Epson Perfection 1200 scanner with windows 7 64bit
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Dec 15, 2009 | Epson Perfection 1200 Photo Flatbed...
156 people viewed this tip
David Payne
David Payne
