Tip & How-To about Computers & Internet
How to change your DNS (Domain Name Server) on your Windows computer. Faster Internet response!
Hi Thanks for looking.
Your ISP (Internet Service Provider) provide you with Domain Name Server which translates website names to language that computer can understand which is an IP address of the website. Faster the response from DNS the faster your website will load.
In this tip I will explain how to change your Domain Name Server (DNS) in order to speed up your web browsing.
Go to
Start--->Control Panel--->Network Connections
Please note that you may need to switch to "Classic view of Control Panel in order to see default view.
Right click on network connection that you are currently using and choose "Properties"From the list in box choose "Internet Protocol (TCP/IP) and click "Properties" below. You will be shown a window with two tabs and in General Tab you will have options to change your IP address (we don't want to touch this)and option to set DNS manually.
Click on " Use the following DNS address"Now you can change your DNS to whatever you like. I recommend "Open DNS" which is faster then most of default DNS's.
Ok to change your DNS to "Open DNS you need to type 208.67.222.222 in preferred DNS box and 208.67.220.220 in Alternate DNS box.Click OK and then OK again.
Bravo! You just changed your DNS.
slow internet, website will not load, speed up my internet, how to speed up my internet
Computers & Internet Logo
What is DNS configuraion ?
DNS configuration is what you do to setup the name server for either a website or for your computer. Domain name servers find the IP (Internet Protocol). Everything that connects to the internt has an IP address. IP addresses are for location the machine. They are of the form xyz.xyz.xyz.xyz where xyz is a number between 0 and 255. A domain name would be something like fixya.com, which is easier for people to remember than the numbers. A Domain Name server translates the name to the numbers. Your ISP has one to do the the translation for you. For a web server (computer that hosts a website like fixya.com, the webhost has a Domain Name Server that allows the computer that runs the webserver to be found. Configuration in that case would be to allow the website to find other sites, and to be found by other sites. For your computer, it would be like this, if you are running windows xp: Change DNS Settings in Windows XP
For a server, here is a more complete description: An Introduction to DNS Terminology Components and Concepts DigitalOcean
May 26, 2017 | Computers & Internet
is asking for dns what is dns
Hi,DNS is an Domain Name System,It is very important for website creating, I got my dream DNS from this http://www.thewebpole.com/ site ,here only the cheap and best DNS available.
Jul 22, 2009 | Belkin (F5D7230-4) Router (587009)
can't get site to publish
Hello kindly try this steps and links in publishing your site on net.
  1. Understand the basics. To publish a web site, you should know what a web site must have to be published. A website has a unique web address like www.google.com or www.yahoo.com. This is called a domain name. Each domain name is registered with a DNS (Domain Name Server), which identifies a domain name with a unique ID i.e. IP address (A bunch of 4 groups of 3 digits each). Then, a web site must have a webspace allocated to it. This is provided by a Web Server maintained by many companies.
  2. Look on the web if the name you want to register for website is still available i.e not registered by anyone. You can search for this on many websites like http://www.networksolutions.com etc. If the name is available, then go for it, or think over a new name.
  3. Note the following. If the name is available, then you should go to an Internet Service Provider and get the name of your website registered. You'll get a unique IP address and domain name from the same Internet Service Provider or another buy a web space for your web site. A normal and usual website can be designed with 5 MB of Web space. Depending on your requirement buy web space. There may be generally two options one on a web server using Windows hosting or Linux hosting. Linux hosting is generally cheaper. Also consider the design of your web site and tools you are using to develop your web pages. These should be available on the hosting web server.
  4. Get your web pages designed and working on your own or by a professional web site designer.
  5. Upload the contents of the web pages (files, Folders etc.) as it is to the web server with FTP address, login and password provided by hosting service provider.
  6. Give yourself a pat on the back! Now your website is ready and running over the Internet. You can see it using http://www.yourdomainname.com
If you need more assistance just reply to this post.
Thanks
Jul 16, 2009 | Microsoft Office Publisher 2007 for PC
linksy router
a DNS server stands for domain name service. The DNS server translatesnames from IP addresses. The internet sees IP addresses such as 209.235.250.53 but the DNS server provided by your ISP translates it for you into fixya.com. You should be able to aquire the DNS server information from your internet provider (ISP) hope this helps.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Mobile Problem
(1) Short for Domain Name System (or Service or Server), an Internet service that translates domain names into IP addresses. Because domain names are alphabetic, they're easier to remember. The Internet however, is really based on IP addresses. Every time you use a domain name, therefore, a DNS service must translate the name into the corresponding IP address. For example, the domain name www.example.com might translate to 198.105.232.4. The DNS system is, in fact, its own network. If one DNS server doesn't know how to translate a particular domain name, it asks another one, and so on, until the correct IP address is returned. (2) Short for digital nervous system, a term coined by Bill Gates to describe a network of personal computers that make it easier to obtain and understand information. ____________________________________________________
Here it is what is DNS. It is your provider's responsibility to give you thir DNS number as it is must to access net. Most of providers prefer to send it directly to your phone as configuration setting. You have to only save it. Some providers give service of setting by their customer care division or area support office. You should ask him for so. Nobody can provide you this information, me also, sorry for that. FIXING your mind....I tried....do vote if so...
Jan 10, 2008 | Samsung SGH-D600 Cellular Phone
1,339 people viewed this tip
David Payne
David Payne
