Tip & How To about Toaster Ovens
Timer Switch Failures
Many toaster ovens use a timer switch to operate the ovens. Many of them use very poorly made Chinese timer switches that make a very poor electrical contact internally causing them to get very hot and in cases will melt connector insulation and also cause wall plugs to get very hot. One in particular is part # DKJ/1-60 which is used in Black and Decker and other manufacturers ovens. Replacement switches are about impossible to find and B&D will be of no help finding one. If your timer switch has only 2 contact tab's on it, you can use this tip to repair your oven. If it has more that 2 contacts, you will need to find a replacement switch or ask a qualified technician about other switches that can be used.
A safe and easy way to fix the appliance is to replace the bad timer switch with a single pole single throw toggle switch. Make sure to get one rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually, but at least you will be able to use the oven and not have to worry about a faulty timer switch overheating! The timers are for convienience only and you have to turn the OVEN feature on and off manually anyway so all you're losing is the timer convienience for toast or whatever and the toggle switches are much safer too. The switches can be purchased at any electrical parts store or at many hardware stores for under $10. A cheap and safe solution to the problem!
If you feel the need for a timer and want to take your chances with a timer switch, there are a couple switches that you can use to replace the DKJ/1-60 switches. They are made for Delonghi toaster ovens and are readily available. One part # is 5218104600. This switch will work the same as the original but it only has about a 15 minute toast timer. Turn counterCW for OVEN ON like the original switch. You may need to use some mounting parts from the old switch depending on your particular oven. Another switch which has a 120 minute timer is part # 5218101800 but may be a little harder to find. Both of these look the same as the DKJ/1-60 and are about the same size with the bell on the back of the switch.
Top Toaster Oven Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Add a Comment
