Tip & How-To about Computers & Internet
How to copy files faster
I use TeraCopy for copy and move files at the maximum possible speed.
It has many features as Copy files faster, Pause and resume file transfers, Error recovery & lot more..
Try it is free for home users. you can download it from here.
Computers & Internet Logo
what does 'file integrity violated' mean?
Hello, Jason.
Go to Add/Remove Programs and uninstall TeraCopy.
Restart your system and try again.
Hope this helps.
Jan 06, 2012 | Computers & Internet
problem downloading files up to 100 mb
Well, here's a bit complicated, yet effective method that just might reduce your downloading headaches... Let's say you're connect to the Internet using a 28.8K modem and that your Internet service provider lets you telnet to their server. Of course, your provider's server can download files much faster, so the idea here is to download the file to their server at high speed, split it, and retrieve parts at the highest speed you can to your provider's server. Generally speaking, this method not only is a faster way to download files, but it is also a more reliable method since you'll be downloading many smaller files rather than one large file.
First, find out the FTP address of the large (larger than 16M for example) file that you want to download. For example:
ftp://ftp.x.com/bigfile.zip
Telnet to your Internet service provider's server.
telnet x.com
From within the telnet session, download your file to your provider's server. Following is a "screen shout" of a sample file transfer on an UNIX compatible server. Blue/bold text represents your input.
ftp
ftp> open ftp.x.com
Connected to ftp.x.com.
220 ftp x.cpm FTP Service (Version 2.0).
User (ftp.x.com:(none)): anonymous
331 Anonymous access allowed, send identity as
Password: my_address@x.com
ftp> binary
200 Type set to I.
ftp> get bigfile.zip
200 PORT command successful.
150 Opening BINARY mode data connection for bigfile.zip
226 Transfer complete.
ftp> quit
221 Thank you for using x.com! Once the file is download to the server, the next step is to divide the file into smaller pieces so that you will not waste too much time downloading should your Internet dial-up connection go down.
split -b 2000b bigfile.zip
You're almost there! Now simply log off from your telnet session and start downloading (from your provider's server to your computer) smaller files (not the bigfile.zip) which the above split command (on most UNIX compatible machines) created.
Once you have all the files, simply merge them and you got a good copy of the original bigfile.zip. If you're using DOS or Windows, you can merge files using the following command (assuming that bigfile.zip (16000 byte file) was divided into 8 2000 byte files named xaa to xah):
copy /b xaa xab xac xad xae xaf xag xah bigfile.zip
Don't forget to log back into your Internet service provider's computers and delete temporary files (bigfile.zip and xaa..xah) once you've made sure that your downloaded copy is in good condition. Doesn't sound like the above steps could make your downloads faster or more reliable? Well, in most cases it does; specially if the file you're downloading is rather large. The reason why this method could possibly be faster is because you can download files from your provider's computer to your computer faster than from most remote sites. Of course, the reason for reliability is that downloading many smaller files makes it possible to resume a download without wasting as much time as resuming a larger file download would.
************ALTERNATIVELY***********
You can use FRESH DOWNLOAD.Fresh Download is an easy-to-use and very fast download manager software that turbo charges downloading files from the Internet, such as your favorite freeware/shareware, mp3 files, movie files, picture collections, etc. Unlike any other similar utilities, this software is 100% free, no charges, no banners in the software (whichsteal your bandwidth), no spyware.
Apr 13, 2009 | Arris Touchstone 450a (CM450) Modem
How to tranfer files from 1 user account to another user account
Copy c:\Document and setting\[user1]\My Document
and paste c:\Document and setting\[user2]\
But,it willl not make pc faster to great extent..
Jan 01, 2009 | Compaq Presario 5000 PC Desktop
Write and read spead slow; only 10MB/s
This has been a commonly reported concern. Here are a few links that may provide a solution to this problem:
Additionally, some Vista users report better file transfer rates using WinRAR & Teracopy.
For maximum file transfer, also check all elements in your network, i.e. switches & routers, etc. For discussion of max speeds cf. here
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 24, 2008 | VisionMan VisionVault 4TB Smart NAS...
cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Nov 13, 2008 | Western Digital Passport WDXML800UE...
179 people viewed this tip
David Payne
David Payne
