Tip & How-To about Baby Gear
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
Baby Gear Logo
what does cosco scenera model 22216-llp
You should see a harness strap over each shoulder that goes though the shell, behind the seat, and connects to a metal splitter plate.
The front of the harnesses (2) extend down though the buckle tongues then into the hip area of the seat.
There is a crotch strap that comes out of the shell where the child\'s crotch is. The buckle is attached to this strap.
There will be a LATCH (Lower Anchors and Tethers for Children) strap that goes through one of two belt paths. If used, this strap must go though the proper belt path.
Finally, there is a top tether strap the comes from the back of the seat - near the top - that will attach to the tether anchor in your car (see your car owner\'s manual)
My suggestion to you is to purchase a new seat. The protection of your child is most important.
Jul 10, 2014 | Baby Gear
sSHOULDER HARNESS SLOT QUESTION FOR REAR FACING IN RADIAN 80
You can use any slots on the Radians for Rear facing so long as there is still at least an inch of shell above the child's head.
Aug 01, 2009 | Sunshine Kids Radian80 Convertible Car...
child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 | Baby Gear
turn airbag off for 5 series bmw
Hi , if you visit a dealer they will be able to let you know how much it will cost to deactivate the passenger air bag.
Mar 14, 2009 | BMW 5 Series Cars & Trucks
4,292 people viewed this tip
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
