Tip & How-To about Electrical Supplies
A class suit was filed and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which lead to the filing of the class suit.
Electrical Supplies Logo
Maytag washer #MAH400AWW drains water fine but will not go into high speed spin cycle
Your washer uses a wax motor door latch assembly with a high failure rate that led to the filing of class suit against Maytag in 2004. The failure of the wax motor results in a no spin problem.
Verify first if the door lock light is on. If not, the wax motor failed and resistor R11 and transistor Q6 on the machine control board also failed. Replace the wax motor and R11 and Q6.
Most technicians will advise you to replace the machine control board and not just the wax motor. But replacing them is not a difficult task. You just need to know how to solder and desolder.
When you opt to ask a technician to repair your machine, insist that only the wax motor, R11 and Q6 must be replaced, not the entire control board. The service will cost you about $300.
Do not hesitate to inform me if you want to do the repair yourself for the complete disassembly and repair procedure.
Jan 13, 2010 | Maytag Washing Machines
I HAVE AN OLDER MAYTAG NEPTUNE FRONT LOAD WASHER MOD# MAH3000AWA. I AM HAVING TROUBLE WITH IT, IT WILL NOT DO THE FINAL SPIN CYCLE IT SPINS WHEN IT WASHES, AND RINSE CYCLE, BUT THE FINAL CYCLE IT JUST SHITS THER, AND DOES NOT SPIN, THERE FOR ALL THE CLOTHS ARE VERY WET.
Maytag Neptune defective door latch wax motor update
by: Anonymous
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune’s also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
Feb 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
984 people viewed this tip
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
