Tip & How-To about Televison & Video
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
/SciPhinx
Televison & Video Logo
loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any suggestions?
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
my xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
CD-RW drive won't open
stick a straight paperclip into the tiny hole in front a few times. This manually rotates the gears and will eject the cd tray.
If it does not still come out because of the jammed CD - you may need to use force!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 08, 2009 | Samsung (sw 252 frns) CD-RW Burner
1,113 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
