Tip & How-To about Zebra 105SL Thermal Label Printer
How to calibrate the label & ribbon sensors on Zebra printers
One of the most common problems with Zebra Xi, XiII, XiIII, Xi4, and 105S,105Se, 105SL series of printers is sensing or proper advancement of the labels. The printer has two sensors, top and bottom, that must be properly aligned with each other. If you are not sure they are aligned correctly, see my other tip on how to align the media sensors.
The label passes between these two sensors. The idea is that the label blocks the light between the two sensors and the gap between each label does not block the light. So the labels advance based on light, no light, light, no light. Note that the red light you see in the “throat” of the printer when you raise the printhead is not the sensor being discussed here. That red light is a “reflective” or “mark” sensor and is used for a different purpose.
Sometimes the labels are on a backing (liner) that is almost as opaque as the label itself. If this happens, then not enough light passes through the liner when the gap passes under the sensor. The printer loses the ability to find top-of-form. We can recalibrate the printer sensors however to adjust to this new liner. My video at the link below will walk you through step-by-step on how to calibrate the sensitivity of the media sensor. The ribbon sensor is recalibrated at the same time. Once this is done, the printer should now easily advance from label to label. The procedure may have to be performed each time for different thicknesses of liners or backing.
Video tip:
Zebra 105SL Thermal Label Printer Logo
Zebra 105Se not working
www.clearprintsolutions.com
Oct 12, 2009 | Zebra 105Se Thermal Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
2,644 people viewed this tip
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
