Tip & How-To about Office Equipment & Supplies
Keeping your printer working
I see so many problems people have with printers, and it's understandable. Printers work great, as long as nothing breaks or jams or the ink cartridges are maintained. To keep ink cartridges from drying up, you should print at least a page or two on a weekly or at least monthly basis. This keeps the ink from drying up on the print ports that supply the ink. Also, there is a heater on HP, Canon, and other printers that is inside the print cartridge. When the ink runs low, the heater element can burn up, and refilling it will not help, a new one will have to be purchased. Dust and dirt and particles can cause havok within a printer, causing sensors to stop working, rollers to stop grabbing the paper correctly, and other problems. Take your printer, occasionally, and, carefully holding it upside down, blow it out with compressed air. Be careful about the scan bed, it can easily break if it flips open too far. If you don't elect to hold it upside down, at least blow it out with compressed air as well as you can. This will minimize problems for you, and make your printer function much longer. Try to keep the printer closed up while not in use, to discourage dust and other things from falling into it. Too much debris, or especially liquid spills can render the printer useless and, at a minimum, expensive to repair. Anything that can jam the rollers, can strip a plastic gear in the roller assembly, and this requires service, and replacement of the gear. Since HP will only send parts to Authorized Dealers (as with other companies), that requires you to have HP fix it, unless you can find a 3rd party repair service.
To conclude, keep the printer clean and free of debris. Print occasionally, to keep the ink from drying up. When not in use, close the printer up, and you can also use printer covers, which used to be supplied years ago, but were discontinued (probably to aid in resales). You can sometimes find them still at certain stores, and used computer shops. Good luck, hope these tips help!
carrier is jammed - won't move to left and I don't want to break it - how do I un-jam? it's an HP PSC 2355
A LIKELY problem has to do with the baffle used for the waste ink during cleaning of the jets cycle.
GREAT care is needed to not force and break plastic parts.
Use an inspection/dental mirror and bright light to see what is blocking the movement.
Sometimes an ink cartridge retainer can come loose and jam it.
Nov 28, 2009 | HP PSC 2355 All-In-One InkJet Printer
check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Just opened box today 12/14/08 error msg: cannot recognize ink cartridges. I just completed step 4-9, checked cartridges 4 times pressed OK BUTTON 4 TIMES, same msg. note: all cartridges are new! checked   step 4 several times. HELP!
Same problem with the one I have. Have always had that problem. Seems like cartridges from Mexico work better. If at first it dont work, JAM IT IN. What the hell, if the printer breaks, you aint lost nothing but a printer that wouldn print anyway.
Dec 15, 2008 | Epson RX595 Photo All-In-One Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
carrier jam
i had the same problem and i'm almost positive it's because i do not have a color ink cartridge in my printer. i called the technical support and they said that both ink cartridges have to be in the carrier for the printer to work. even if one of them does not have ink in it. hope this helps. (for me too)
Dec 18, 2007 | Dell 924 All-in-One InkJet Printer
157 people viewed this tip
jasbo
jasbo
