Tip & How-To about Computers & Internet
How to put your name on Web browser's title bar ?
We can put our name or desired text on Web browser's title bar.
it will be go through using registry editor. but, you have to take backup for registry before doing this.
otherwise, you no need to worry about this simple method.
Operating system: Windows XP Professional
Example browser on: Internet explorer
go to start -> run -> regedit ->
try to search for this below key:
HKEY_CURRENT_USER\SOFTWARE\MICROSOFT\INTERNET EXPLORER\MAIN \
here, you will see an option "window title" in the right side page.
or you can just create a string value in the right side by using right click on the mouse.
you can also change the start page of browser like google.com
just edit on the start page in the right side page.
thanks,
Computers & Internet Logo
uimain exe
If you have sufficient computer expertise to deal with superior PC problems, you may consider repairing registry problems simply through built- in Registry Editor. Before editing the Windows registry, you need to make a backup for the registry files:
  1. Click Start, and then select Run, and type REGEDIT on the pop- up. Click OK.
  2. In the Registry Editor, select the registry key you need to back up.
  3. From the Registry menu, select Export Registry File option.
  4. From the Save In list, click the folder where you want to save the backup.
  5. In the File Name box, type a name for your backup file, such as "Options" or "Backup."
  6. In the Export Range box, be sure to select "Selected branch" option.
  7. Click Save. The file is saved with a .reg extension.
Once finishing backing up the registry files, you are allowed to edit the registry manually:
  1. Click Start, and then go to Run.
  2. Type "regedit" onto the dialog box, and then press Enterto enable Registry Editor.
  3. Find out HKEY_LOCAL_MACHINE folder and double click to open it. Then click "Software" folder, go to "Microsoft" folder, select "Windows" folder, click"Currentversion" Folder.
  4. Click "Run" folder ==> Click on the UIMain.exe file.
  5. Click Delete UIMain.exe key to remove the file.
Jul 16, 2013 | Computers & Internet
IN FEW DAYS I SEE THAT SUDDENLY THIS CD/DVD DRIVIE IS LOST MY COMPUTER.WHEN I RESTORE MY SYSTEM IT WILL BE COME BACK ITS WON POSITION.THIS EVENT OCCUR 4 TIMES WITH MY COMPUTER.WHAT CAN I DO FOR THIS? AND I MUST SAY THAT I WANT TO DOWNLOAD THIS DRIVER SOFTWARE.WHERE CAN I FIND IT? MY LAPTOP MODEL NO - ( NP-R480-JSO1IN). PLEASE SEND MY PROBLEM SOLUATION AS SOON AS POSSIBLE AT MY EMAIL- senguptaluv@gmail.com. THANK YOU
From the problem description I understand that the CD/DVD Drive is not visible in the Computer window. Also, I would suggest that check in Device Manager if the CD/DVD Drive shows yellow exclamation mark.
In both the cases, please perform the steps below to delete the upper and lower filter values from the registry: Before performing the below steps, better take backup of the registry if something goes wrong, you can open the Backup file to restore the old registry values:
STEPS TO BACKUP THE REGISTRY
  1. Click the Start button, and then in the Search field, type regedit .
  2. Press the Enter key. NOTE: If prompted for an administrator password or a User Account Control prompt is displayed, type the appropriate password, click Continue or click Yes .
  3. In the Registry Editor window, on the menu bar , click File .
  4. In the File menu, click Export .
  5. In the Export Registry File window, under Export range , click the All radio button.
  6. In the File name box, enter the name for the exported file and then click the Save button.
  7. In the Registry Editor window, click the X button at the upper-right to close the Registry Editor.
STEPS TO DELETE UPPER AND LOWER FILTERS TO RESOLVE THE ISSUE WITH THE OPTICAL DRIVE
  1. Click the Start button, and then click Run .
  2. In the Run window, next to Open: , type: regedit .
  3. Press the Enter key.
  4. In the Registry Editor window, in the left pane , double-click the HKEY_LOCAL_MACHINE folder.
  5. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  6. In the System folder, double-click the CurrentControlSet folder.
  7. In the CurrentControlSet folder, double-click the Control folder.
  8. In the Control folder, double-click the Class folder.
  9. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  10. In the right pane , click to select the UpperFilters registry value.
  11. On the menu bar , click Edit .
  12. In the Edit menu, click Delete .
  13. In the Confirm Value Delete dialog box, click the Yes button.
  14. In the right pane , click to select the LowerFilters registry value.
  15. On the menu bar , click Edit .
  16. In the Edit menu, click Delete .
  17. In the Confirm Value Delete dialog box, click the Yes button.
NOTE: Do not delete the UpperFiltersBak orLowerFiltersBak registry values.
  1. Close the Registry Editor window.
  2. Restart the computer.
This will resolve the issue.
Thanks!!!!
Dec 30, 2010 | Computers & Internet
the presence of rahul the hacker in my web page
Hi Gracy
you just open your registry editor by pressing Win key + R.And then typing regedit.When the registry screen appears go to the edit tab in the menu bar and search using find  for rahul for all value,keys,data.
When it is found just delete the portion you want from the line.....
Hope it wud set things right.............
Feb 06, 2009 | Microsoft Windows XP Professional With...
220 people viewed this tip
David Payne
David Payne
