Tip & How-To about Cameras
Camera lens does not extend/retract! Maybe it is the batteries!
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance non-rechargeable batteries (ie. "Lithium" Duracell or Enegizer) normal alkaline batteries will not be able to charge the Flash. Even if you buy new batteries it doesn't mean they are fresh. Batteries have expiry date and can go bad after a couple of years. If you are using high performance batteries then it is sadly your camera which is faulty. Some times repairing the camera could cost you more than buying a new one. If it is so in your case, before losing all hope completely,
OBS! ACHTUNG!
Read all the way down before attempting the steps below!
-Firstly vacuum clean it, and then some mild violence could help ;) ..
-Try to turn the lens/ objective back and forth manually (YES, ONLY TRY! NOT DO! ONLY PUT A LITTLE PRESSURE ON IT!) OBS! OBS! this could damage the camera beyond repairable state!! I wont be taking any responsibilities!!.
If there is dust and dirt jamming the mechanical parts that should do the trick!
Be careful and Good luck!
Your upward Thumbs are highly appreciated ;)
SciPhinx
Cameras Logo
Batteries good, but screen shows :batteries empty?
How you know batteries are good? Sometimes new batteries are bad too. Also there is a possibility that you are using wrong type of battery like normal carbon batteries or lower ampere batteries which work fine in other gadgets but will show empty in a digital camera. Digital camera need high ampere batteries like Duracell (if your camera use AA batteries) or rechargeable NI-MH/ Li-ion batteries.
May 12, 2011 | Cameras
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
2,455 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
