Tip & How-To about Washing Machines
Water will not stay in Washing Machine
The fix for this is very simple. But you are not alone here this is a common problem so I decided to write a tip about this to help people solve this before posting a question or possibly a having to pay for a service call, for something that can very easily be fixed by themselves.
If the water is going right through your washing machine, then, either one of two things is happening. Either the hose is not going up high enough before it goes back down into the pipe, or the hose end is stuck into the water in the pipe and the result is that the water then can siphon out.
First thing to check is that the hose is going up to a point at least as high as the top of your washing machine before it turns and goes back down into the washer.
Next, check that the water level in the pipe is not backed up so that the end of the pipe is in the water. There needs to be an air gap so that you break the vacuum on the hose after the washing machine is done pumping out. If this does not happen the water going in will just get siphoned right out again...
Checking these two things will solve your problem and you will be happy and washing again!! Hopefully this will save you some aggravation and possibly some money by not having to call for service on a very simple problem. Now, as a service person, I really do not mind these types of calls, but I do hate to charge people for fixing something this simple.
http://www.fixya.com/support/r4312694-washing_machine_maintenance
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r4356970-clean_washer
Washing Machines Logo
internet explorer has stopped working
A common issue. Re boot and look for Windows updates.
Jan 20, 2014 | Acer Aspire One D270-1865
Tips in Speeding Up Windows XP
Hi. There is a good solution for optimizing your PC - registry etc and delete of temporary files etc. Use the program CCcleaner. You can optimize the registry in A SAFE WAY. Can be found here: http://www.piriform.com/ccleaner For people using old operating system win98 - use the ccclearer version 2.26 or earlier. Later verisons need win2000 or later - XP, Vista etc
Jan 14, 2011 | Computers & Internet
My AT&T U-Verse remote control is not responding anytime I click it. Does anyone have a solution?
Hi Yoav! The AT&T remote control from U-Verse can be quite buggy sometimes-- trust me when I say you're not alone.
Thankfully, the fix is quite simple and should only take you a couple of minutes. If this doesn't work you need to get a replacement remote.
All you have to do is turn your receiver off, keep it off for about a minute, and turn it back on again. For whatever reason the U-Verse remote and your cable box will intermittently lose the ability to interact with one another, but going through this type of "soft reset" will usually solve the problem.
I know AT&T has had this issue for awhile but it looks like they haven't been able to solve it yet. Big surprise right?!?!
Mar 01, 2012 | AT&T UVerse
i got error lens ..I couldn't close its lens. Can you help me solve it?
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Dec 04, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
4,911 people viewed this tip
Top Washing Machines Experts
